macOS Sequoia
I re-uploaded it
In your EFI you have a series of Broadcom kexts loading before your core kexts such as Lilu, VirtualSMC and Whatevergreen. Those really should all load first but probably worked anyway. I disabled them and then changed Misc/ Security to Disabled which was probably the issue.
Unfortunately, no success! I've been trying it for a while. I'll update my working EFI (SONOMA) with the new patches etc. and try it again.
I assumed you already had updated the kernel patches so my bad, that's mandatory and then changing Misc/ Security to Disabled at a minimum.
550 / 5.000
I was able to test this EFI up to 14.6.1. It works well. Since I have a Broadcom card, I tried the new kext straight away. It boots under 14.6.1, but I get a black screen for at least 1-2 minutes and no WiFi. If I deactivate it, everything goes back to normal.I updated the Seqouia patch and the kexts are all debug versions. Only the apple appears and then it stops. It can only be something small.Can someone take another look... maybe the bootarg is wrong or is a kext causing the problem?
You didn't update the kernel patches properly, the Max Kernel value is still set to 23.99.99, which refers to Sonoma, and so will not load when trying to run Sequoia. That value should be 24.99.99 instead. You probably didn't download the beta version of the patches, you have to switch from "Master" to "Beta' on the github page.
Also I would suggest you add -v to your boot arguments so yo can see where it stops and then take a picture and post for more help
Your Patches
Sequoia Patch
Do you have a link for me? I can only find the normal ones but no beta ones.
On the Vanilla AMD GitHub page on the left hand side there is a button that says “ Master”. Click on it and see in the drop down menu it says “Beta”. Click on that and download the patches.
First of all, thank you very much for your help.
I have added the patches again, but unfortunately it still hasn't worked. I don't know what to do next.
    EFI.zip
Did you also update kexts? Lilu, VirtualSMC etc? You've got the patches updated but you've not added your core count again.
Edit:
I've unlocked the Sequoia sub-forums. Please use these now for support. Keep this topic for discussion about Sequoia.
He is talking about the Kernel/ Patches you need to run macOS on an AMD machine. You adjust the core count depending on how many cores your processor has.... brain fart maybe?
  • Love
Reactions: Deleted member 4886
When using the latest macOS Sequoia Beta 6/15.1 Beta/Pubilc, a gray interface with a prohibition symbol appears when booting up. The AMD kernel patch used is the latest beta version, which cannot be solved by OTA or clean installation. This is my EFI file. Could you please help me check what this problem is 🙏
Additionally, this article was translated from Chinese using Baidu Translate, which may result in some incorrect wording. My English is not very good 😂
原文:使用最新的macOS Sequoia Beta 6/15.1 Beta/Pubilc时,开机显示一个禁止符号的灰色界面,所用的AMD内核补丁为最新的beta版本,OTA或干净安装均无法解决,这是我的EFI文件,求各位帮忙查一下这是什么问题🙏
The prohibited sign usually means the USB port you are using is not recognized, it could be something else but it's impossible to do anything but guess unless you provide a list of all your hardware. Please include the type of SSDs you are using as well
The configuration of my computer is:
CPU:AMD Ryzen 5 5600G (Blocked Core Graphis Card)
RAM:Kingston 16GB X2 DDR4 3200MHz
GPU:AMD Radeon RX 590
SSD:WD Blue SN570 1TB
Excuse me, is that what you mean? Machine translation may make mistakes.
禁止标志通常意味着您正在使用的 USB 端口无法识别,它可能是其他东西,但除非您提供所有硬件的列表,否则除了猜测之外,什么也做不了。请同时提供您正在使用的 SSD 类型
这是我的 USB SSDT
Yes however you didn't list your motherboard or your wireless card. Is it a B550 variation? Your EFI is mash up so no real help until you finish clarifying your hardware.
My motherboard model is MSI Mortar B550M Wifi(machine translation from CN)
Reactions: leesurone
And which Wifi Card? AMD for Intel? Either can be included.
I know Shaneee wants you to create another thread but see if this helps. Opencore, kexts and patches updated, all bluetooth and wireless kexts deleted
3Q Thank you for resolving my issue. The Security model was set to Disable, which caused the inability to perform OTA updates
