These messages are normal. They should end when the installer reached the next stage.Hello,
Unfortunately I cannot start the setup. The VM was created under VMware 17.5. However, a VM with hardware compatibility 17.0 was also created as a test. Neither led to success. The following loop appears in the bootlog:
WOW!
I managed a little better by changing the SMBIOS as shown in this post:Performance is a dog though. any tips editing the plist to improve speed?
Hello,
Really! You're right.WOW!
It seems that users following this post are iphone developers who need to save big money on buying ridiculously expensive Apple gears!
You must also read my post carefully:
Mac OS install on AMD Ryzen (VMWare) Opencore
I wrote this tutorial to help AMD users create their own version of macOS in VMWare where I believe the system runs more smoothly. 1) First you need to download VMWare from the official website and install it by choosing the free, non-commercial version...forum.amd-osx.com
Did you set this up in VMWare?
This is mostly due to the fact that VMWare does not support macOS graphic acceleration. Another Ubuntu VM is much faster.Performance is a dog though. any tips editing the plist to improve speed?
you mean through kvm and gpu pass through right?This is mostly due to the fact that VMWare does not support macOS graphic acceleration. Another Ubuntu VM is much faster.
In Windows, turn off "Memory Integrity" in Core Isolation. This will make the boot process time much faster!Yes, that's exactly how I did it (in VMWare 17.5) Now I simply gave the boot process more time and now the installation worked perfectly!
Really?!?! What is your host OS?Hi,
i have noticed that macOS starts and works much faster in Vmware if you set the guest operating system to Windows 10x64! Unfortunately, the keyboard no longer works properly. It runs i think because OC-EFI pretends to have a Mac hardware environment anyway.
Windows 11x64 on AMD Ryzen 9 3950XReally?!?! What is your host OS?
It's true. I tested it and the keyboard doesn't work. I don't know if there are any Opencore settings that can solve this.Hi,
