Hi CaseySJ,I'm having some problems trying your efi, could you check it out for me?
BIOS
- Enable epon 2
if i enable SVM.the log may be similar to zgamer109.
if i disable SVM
- Ryzen 9 7950 X
- GSkill 32 x 2 6000
- NVME SSDS: ZHITAI_TiPlus7100 ZHITAI_TiPro7000
- Asus ROG X670E - E Gaming WIFI
- Sapphire RX 6600
- Colorful iGame GeForce RTX 4070 (disable GPU in DP)
BIOS
- Enable epon 2
Thank you @CaseySJ This guide has been tremendous. I figured out the whitelist part and I think I got that set, I had to select the macOS partition in order to find it in the logs. Now Im stuck on the following error: RadeonSensor initializedRadeonSensor freeingupACPI when I see it in Verbose...forum.amd-osx.com
if i disable SVM
