zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
kalkmann
with the 6600m, and you have the rear ports working for usb drives?
Yes, with the 6600m. Turning off the XHC1 controller, in mine all the rear ports work. I was without the 2 side ports and bluetooth of the AX-210. I'm using an Orico external dongle for bluetooth.
I'm already using the laptop for editing work in FCPX and adobe package in Ventura. Stable and fast. I'm already happy I'll wait patiently for new discoveries about Sleep and Trackpad.
OG Nerd
Hello, my GitHub repo has received a number of updates including a new workaround to the USB issue, with SSDT-XHC0-DISABLE, we are disabling the XHC0 controller which houses: the internal camera, the USB port on the left and the USB-C port. Disabling this controller results in a perfect boot with the other USB ports fully working.
can you please link your github, I would like to try the legion 5 again.... (its been sitting collecting dust lol)
Jo-Toku
wow man congrats! Hs anyone here with the 5800h had the same success. Im curious as to why the 8 core doesnt work the same way that is so weird
kalkmann
I never used github (for this purpose). I'll study and send the link when it's ok
It's in the OP.
kalkmann
Repo address: https://github.com/kalkmann/Legion-5600H-Hackintosh
It was the first time I used github to publish anything (in addition to the little experience with AMD hacks), so don't expect anything elaborate and constantly updated.
Thanks to everyone here, especially @ExtremeXT for the help, the original concept of disable one USB Controller, corrections and repository template that served as basis. Hope it helps someone!
kalkmann
Thank you all for your efforts, disabling XHC1 according to @kalkmann's method, successfully getting rid of GenericUSBXHCI.kext, this is another great breakthrough, Legion 5 can finally be used and installed normally after many difficulties, thank you
The original concept of disabling one USB Controller is from @ExtremeXT in this post below. Thank you!
OG Nerd
Awesome!!! Thank you! I will try it this upcoming week and report back!
redhorse1990
Jo-Toku
zxc2689963
  • EFI-13.3.zip
