and this is often a big errorI may borrow these kexts form your build![]()
my advice is to test your system with a minimal EFI without too much kexts
then then your system starts as you like you can refine USB for wake or WIFI/BT I use a Fenvi t919 (internal WIFI/BT Hero disabled)
Our System has also ASMedia USB controller and these kind of USB could be problematic to wake from USB (keyboard or mouse) if you disable ASMedia Controller you could have wake from sleep with power button or via USB devic
I prefer to use External usb ports connected to ASMedia controller, so I can live with wake as I have (only with power button)
Our system has some features that others here dont have (6 sata ports in two Sata controllers), but with some patience all is working fine
Thanks to enormous job done by @CaseySJ here we have a pretty well working system
