Hello, im getting this when updating to .0.8.7 is hackindrom..this is from 8.6, if i do a fresh efi and go to 87 i get a million issue- so im just posting the
point update.
Kernel->Patch[23]->Replace requires ReplaceMask to be active for corresponding bits!
Kernel->Patch[24]->Replace requires ReplaceMask to be active for corresponding bits!
CheckKernel returns 2 errors!
Completed validating /var/folders/77/1dj_w62j747f1ffbdy020v1r0000gn/T/HackinDROM/standalone/EFI/OC/config.plist in 1 ms. Found 2 issues requiring attention.
Casey, i tried your other 2 patches for my 10g card and i have the same audio studder issue when clicking carbon. I will upload my efi folder so you can double check everything is ok for this board. im hoping oc 8.7 will get carbon working...please check the quirks as your guide has a few differnt quirks then what i have set from am4 cpu.
I am able to boot pro tools now and using my rme card, if i just can get avb going and it will be good news for the audio community here.
