Dunno If it can help, I've an ASRock Z690 with ALC897, alcid=12, Intel CPU obviously, perfect audio, to try to extract some info from a working similar audio codec.
Besides that, I'll try a simple free game to see if there are stutterings and desyncs just like with sound, WITHOUT speedkeeper:
Even this bench with sound can help, so we can compare real numbers: https://benchmark.unigine.com/valley
Then I'll try to get rid of the fix pat patch now that pciex bus is fixed, or try Shaneee's one if that doesn't work instead of Algrey's default one.
Just tried these patches with Monterey because MaxKernel is 21.99.99. Alas, static is about the same.
Let me grab HWINFO / CPUZ information from Windows next. May take an hour or two.
@ExtremeXT,
Attached is the CPUZ report in HTML format. It should open in Safari or Firefox. Windows was booted without OpenCore.
An extract:
Core Speed5497.0 MHz
Multiplier x Bus Speed55.0 x 99.9 MHz
Base frequency (cores)99.9 MHz
Base frequency (mem.)100.0 MHz
Instructions setsMMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, AVX512F, FMA3, SHA
Microcode Revision0xA601203
L1 Data cache8 x 32 KB (8-way, 64-byte line)
L1 Instruction cache8 x 32 KB (8-way, 64-byte line)
L2 cache8 x 1024 KB (8-way, 64-byte line)
L3 cache32 MB (16-way, 64-byte line)
Max CPUID level00000010h
Max CPUID ext. level80000028h
FID/VID Controlyes
# of P-States2
P-StateFID 0x8B4 - VID 0xC9 (45.00x - 1.256 V)
P-StateFID 0x878 - VID 0x79 (30.00x - 0.756 V)
PStateReg0x80000000-0x4B7248B4
PStateReg0x80000000-0x479E4878
PStateReg0x00000000-0x00000000
Reactions: ExtremeXT
And here is HWINFO64...
  • Wow
Reactions: Galve2000
Here are some TSC (Time Stamp Counter) and FSB (Front-Side Bus) calculations performed by following the code below, which however is for AMD Family 17h instead of 19h.
C:
            cofvid  = rdmsr64(AMD_PSTATE0_STS);
            CpuDfsId = bitfield(cofvid, 13, 8);
            CpuFid = bitfield(cofvid, 7, 0);
            cpuMult = (CpuFid / CpuDfsId) * 2 ;
            // Fix for audio desync on APUs
            if (cpuid_info()->cpuid_stepping==0 && cpuid_info()->cpuid_extmodel==1) {
                tscFreq = EFI_CPU_Frequency();
                busFreq = EFI_get_frequency("FSBFrequency");
            else{
                tscFreq = (CpuFid / CpuDfsId) * 200 * Mega;
                busFreq = tscFreq / cpuMult;
            tscGranularity = cpuMult;
  • CPUZ screenshot shows that this processor has two P-states:
  • Assuming that AMD_PSTATE0_STS refers to the first of these two P-State vectors (i.e., the highest P-State), we see that the FID is 0x8B4
  • We also see that the full vectors are (EDX:EAX):
UPDATE: 16 Nov 2022: JUST FIXED MY BAD LATE NIGHT MATH!
P-State-0 (Vector 1)
  • So let's assume cofvid = rdmsr64( AMD_PSTATE0_STS ) gets back the value 0x4B7248B4 where the first 16 bits (0x48B4) are 0100 1000 1100 0100
  • Then CpuDfsId equals bit-field 13..8 which is 0x08
  • And CpuFid equals bit-field 7..0 which is 0xB4
  • Then cpuMult = (CpuFid / CpuDfsId) * 2 or 0xB4 / 0x08 = 0x2C (44)
  • Therefore:
    • tscFreq = (CpuFid / CpuDfsId) * 200 * Mega = (0xB4 / 0x08) * 200 * 1,000,000 = 4,400,000,000
    • busFreq = tscFreq / cpuMult = 4,400,000,000 / 0x2C (44) = 100,000,000
P-State-1 (Vector 2)
  • If we perform these operations for the second P-State vector, we get:
  • cofvid = rdmsr64( AMD_PSTATE1_STS ) gets back the value 0x479E4878 where the first 16 bits (0x4878) are 0100 1000 0111 1000
  • And CpuFid equals bit-field 7..0 which is 0x78
  • Then cpuMult = (CpuFid / CpuDfsId) * 2 or 0x78 / 0x08 = 0x0F (15)
  • Therefore:
    • tscFreq = (CpuFid / CpuDfsId) * 200 * Mega = (0x78 / 0x08) * 200 * 1,000,000 = 3,000,000,000
    • busFreq = tscFreq / cpuMult = 3,000,000,000 / 0x0F (15) = 200,000,000
Unfortunately neither set of numbers solves the audio stuttering problem. This is how the numbers were entered (vector 2 in this case):
Hi everyone,
With the progress reported here, am I correct in my understanding that an external DAC wouldn’t have audio issues?
Hi everyone,
It depends on the DAC. My external audio DAC with Sabre ESS902x and XMOS USB still has audio issues, but those issues are significantly mitigated by running SpeedKeeper.
the external DAC must have it's own timer to avoid the sound issues.
Reactions: CaseySJ
@CaseySJ could you try to limit your cpu cores as I do in this picture
in your pc you could try to use 4,2,1 (cpus=x)
to see if audio is better (without the trick you have found)
How can we determine if an external DAC has its own timer? Here’s what macOS shows about the DAC I’m using:
I am currently booted up with cpus=4 and playing my favorite YouTube music video (Disturbed's Sound of Silence). Playback is much improved, but still choppy, as follows:
When CPUs are busy like this, sound is good (not perfect, but much improved):
When CPU activity drops like this, then audio stuttering comes back in full force:
This is the theory behind SpeedKeeper. When SpeedKeeper is running, CPU activity looks like this, but audio is significantly improved (not perfect, but significantly better):
during high load you should try to see in terminal if some TSC values change compared in idle situation (with usual grep command)
I do not know if it is available a real time monitor to check TSC values..to see when audio is crappy what happens... but maybe it is unrelated
Try disabling Core P-States, Cool&Quiet and other power saving features which would make it downclock. Do a backup of your BIOS settings before this.
Reactions: etorix
The command...
Bash:
sysctl -a | grep -e tsc -e freq
...shows the same values when invoked repeatedly:
Bash:
% sysctl -a | grep -e tsc -e freq
kern.hv.clock.tsc_base: 241525761840
kern.hv.clock.tsc_clock_last: 0
net.link.fake.switch_mode_frequency: 10
net.pktsched.netem.heap_size: 2048
net.pktsched.netem.sched_output_ival_ms: 1
net.pktsched.verbose: 0
hw.busfrequency: 408000000
hw.busfrequency_min: 408000000
hw.busfrequency_max: 408000000
hw.cpufrequency: 4500000000
hw.cpufrequency_min: 4500000000
hw.cpufrequency_max: 4500000000
hw.tbfrequency: 1000000000
machdep.tsc.nanotime.tsc_base: 223238618325
machdep.tsc.nanotime.ns_base: 0
machdep.tsc.nanotime.scale: 954435759
machdep.tsc.nanotime.shift: 0
machdep.tsc.nanotime.generation: 2
machdep.tsc.frequency: 4500006684
machdep.tsc.deep_idle_rebase: 1
machdep.tsc.at_boot: 0
machdep.tsc.rebase_abs_time: 49608508072
machdep.cpu.tsc_ccc.numerator: 0
machdep.cpu.tsc_ccc.denominator: 0
It seems that changing FSBFrequency and initialTSC in OpenCore does not change the values we see here. These are after changing FSB to 200,000,000 and TSC to 6,000,000,000.
Bash:
kern.hv.clock.tsc_base: 234469918485
machdep.tsc.nanotime.tsc_base: 212930989155
machdep.tsc.nanotime.scale: 954436207
machdep.tsc.frequency: 4500004571
machdep.tsc.rebase_abs_time: 47317949425
@CaseySJ Try this for the I225-V.
Note: Your ACPI path for the SSDT will 99% be different on AMD.
Reactions: PoMpIs and CaseySJ
Will try this soon. Will also check whether P-states in BIOS can be disabled (for audio issue).
Disabling the P-states I have tried and it did not solve the audio problem, it was still bad 🤷‍♂️
