Clean Install - new volume/partition needs to be formatted as APFS.In the past JHFS+ was use, but now the installer fails if the drive was formatted to JHFS+ prior to install.
Discovered the new AppleIGB Ethernet connection has been stable for the last few hours. Make sure if your try it to delete or disable SmallTree in your config. Will evaluate the performance and stability before updating the 0.8.6 EFI posted yesterday.
I do not use the sleep function, just turn off the monitor after a bit. Therefore, I will not be testing the stability after sleep.
That message usually appears for two reasons - a brand new disk or a disk with linux on it - NacOS can read windows partitions just fine, a driver is needed (e.g. Tuxura) to write to them.
Unlike windows, that message is meant to prompt you to fire up disk utility and have a look at your drive configurations and prepare a new drive for use. Windows will just blindly ignore the drive leaving newbies to wonder "where my new 10Tb hard drive?"
Included Kexts (Disabled)
OpenCore 0.8.7 and going forward, the following Kext are included in the EFI but disabled by default.
This was done due to problems with AMDRyzenCPUPowerManagement & SCMAMDProcessor kexts causing boot loop and crashing with Monterey. Certain header changes were required for Ventura that are not always compatible with older versions of Monterey.
Now also included in the EFI are some commonly used Kext for the NVMe and hardware sensors along with compatibility for third-party hardware reporting apps like iStat Menus.
Intel 1GB Ethernet now works using AppleIGB
Realtek 2.5GB Ethernet using SmallTreeIntel82576 combined with LucyRTL8125 (both must be enabled). Recommend using only one Ethernet solution as SmallTreeIntel82576 prevent AppleIGB from working.
Enable the kexts as need at your own peril.
NVMe
NVMeFix -> Patches for the Apple NVMe storage driver
AMDRyzenCPUPowerManagement.kext -> Power management features
AMD Power Gadget App
V 0.7 Older Version - Kext included in EFI - Shows CPU Temperature in third party apps (custom version of AMDRyzenCPUPowerManagement & SMCAMDProcessor kexts by trulyspinach)
V 0.7.1 Current Version - Does not show CPU temperature in third party apps, download and update kexts manually
LucyRTL8125Ethernet -> Driver for Realtek RTL8125 2.5GBit Ethernet Controllers
Sensors & Third Party Apps (iStat Menus): CPU & GPU temperature + Fan Speeds in iStat Menus (Bottom Fan = Motherboard CPU Fan Header & Blower = Motherboard Chassis Fan header)
SMCAMDProcessor.kext -> Publishing sensor to VirtualSMC
SMCRadeonGPU.kext -> Export GPU temperature to VirtualSMC
I guess I jumped the gun on the 0.8.7 release. I see on the build repo that changes were made just and hour ago. It might be a bit before it is actually released.
I have been running the Pre-Release 0.8.7 for about a week. Nothing of note for X570 & B550 motherboards has been added. Runs just fine.
Included Kexts The following commonly used kexts are included but disabled by default. Enable the kexts as need at your own peril.
NVMe
NVMeFix-> Patches for Apple NVMe storage driver
AMDRyzenCPUPowerManagement.kext-> Power management features
SMCAMDProcessor.kext-> Publish sensor to VirtualSMC
SMCSuperIO.kext -> Read fan speeds
Reset NVRAM after making changes to the EFI.
Thanks for the EFI. After a bit of struggling (haven't done a hackintosh in ages), I was able to get my Crosshair VIII Impact, 3090 and 6800x up and working.
I'd love to get my bluetooth working though. Will none of the OpenIntel BT/Wireless kexts work with the on-board chips?
You may be able find Kexts for your specific wifi and bluetooth hardware if you search around. But the native Apple services will not work. If you have an extra PCI slot an add on card maybe the easiest solution.
One caveat to using the Broadcom solutions is that Continuity Camera does not work.
A small Broadcom based bluetooth dongle should work. I have used several different bluetooth dongles with the supported Kexts to try and find a solution to the Continuity Camera issue with no luck. But they work for general bluetooth well.
I was able to get bluetooth working with a dongle, but I'd love to get wifi going for location services. I'm using a DTX motherboard, so using add-on card is a no go unfortunately.
Anyone have a solution for getting wifi up and going, or can suggest a dongle that would work with Ventura?
after a normal reboot I discovered that Ventura 13.0. didn't find the Web anymore. I get this red icon with "no WIFI-Plugin!". I have a incompatible E1000 and depending highet on WLAN! What I did: ...
github.com
The Link to Chris111's Github page also has a link to a list of compatible adapters, so you are not restricted to the Archer TU3 adapter.
If you purchase a WiFi device from Amazon and it doesn't work as you need, you can always send it back within the 30-days transaction period. That way you can get your money back or an alternative WiFi device.
