zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
@ExtremeXT
Please help me
My configuration is a MediaTek network card. The pm8512 is solid. Everything else is the same. I installed the macos on another computer: macOS Monterey 12.6. Do I have problems upgrading to it.
我的配置是联发科网卡,pm8512固态,其他都一样,macos是我在另一台电脑上装好的:macOS Monterey 12.6,我是升级上去的这样会有问题吗。
EFI: https://github.com/extremegrief1/Lenovo_Legion_5_Hackintosh
I got the Alienware Area51m R2 with the RX5700m (these are unicorns/ very rare) Pretty much I got almost everything running. The trackpad is not working although others have made it work. Under Big Sur the 5700m was not performing well, but Apple fixed the graphic drivers on Monterey and I get full graphics acceleration now.
Since this laptop can switch GPU's up to a 200 watts 2080 Super. I might Unlock the RX5700m TGP of 125 to 150watts. That should give me more of an uplift in performance. These behemoth uses 2 AC adapters, so currently 660watts.:ROFLMAO::ROFLMAO::ROFLMAO:
Can I Install Mac OS on Legion 5 - AMD Ryzen 7 5800H - RTX 3050TI?
CPU: Ryzen 7 5800H
GPU: RTX 3050TI
RAM: 2x 8GB 3200MHz DDR4
can't because Apple not supported for NVDIA RTX Series
Reactions: ExtremeXT
Reactions: OG Nerd
Well actually you can, we just need to disable the 3050TI using a SSDT-Disable-DGPU.aml.
It is possible because of recent new developments we've made for the AMD IGPU. Whilst there is no acceleration it can run in VESA mode in say Monterey.
The EFI is found here and can work with most AMD Ryzen APUs > https://forum.amd-osx.com/threads/how-to-install-on-my-laptop-the-specs-are-below.3176/#post-22802
If there is no graphics acceleration then is rather pointless. Everything would be choppy and sluggish
Actually yes and no. For 3D work obviously it won't work but I find it works rather well with playing video or music. Youtube, VLC or music playback is definitely not a problem.
Why not use the Legion 5 EFI? It should work.
No, the Legion 5 EFI is specifically set up for the RX6600M so it can't be used. Plus I found it had a few errors. Plus the one I uploaded recently for the APU is more up to date.
@zxc2689963 @OG Nerd
If you want to test, use the EFI from the main branch (https://github.com/extremegrief1/Lenovo_Legion_5_Hackintosh/tree/main). I added some stability and bug fixes. If it works fine for you, please try the fix-usb branch (https://github.com/extremegrief1/Lenovo_Legion_5_Hackintosh/tree/fix-usb). If you get any panic, take an image and send it.
- ExtremeXT
I downloaded your EFI from the main fork on your GitHub... Make a new 12.6 Installer and tried booting off it, I end up at the same place as a couple others.... I get the USBToolBox: XHC0: waitForMatchingService failed or timed out error then after a few minutes it goes to the forbidden symbol. Here are the specs of the machine... Legion 5, (I am able to boot into Big Sur with old EFI), 5800H CPU, Ryzen 6600M, 40GB RAM, 2 XPG Gammix X70 Blade NVME SSDs.
I have tried your main fork EFI unmodified, modified to disable USBXHCI.Kext & change system info, I tried the USB-Fix fork as well with same results.
Has anyone come up with a solution to get past the USBToolBox: XHC0: waitForMatchingService failed or timed out error?
Your SSD is probably unsupported, try disabling NVMeFix or maybe disabling USBToolBox.
With nvmefix and usbtoolbox disabled, I now hang at the stage below then goes to a forbidden sign....
I was having problems installing. So Installed it on a desktop computer. Once installed Monterey successfully I inserted the drive back to the legion and use the EFI posted here and boots right up
except the trackpad and drives hooked to the usb ports. Note. No sound from speakers, but do work under Big sur
I was having problems installing. So Installed it on a desktop computer. Once installed Monterey was successfully I inserted the drive back to the legion and use the EFI posted here and boots right up
For the trackpad, you will need SSDT-GPIO. aml enabled plus VoodooI2C, VoodooI2CHID and VoodooPS2Controller.kext.
AMD I2C trackpads don't work
Reactions: Middleman
Stop at the forbidden sign because there is GenericUSBXHCI.kext, you need to cancel all kext related to USB before you can install it successfully, you need to restart the computer constantly, it will boot into the system successfully one time, and the USB controller will take effect probabilistically. I don't know why, or upgrade to monterey12.6 directly in bigsur.
