zxc2689963
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
  • EFI-2023-10-5.zip
Solution
Panic from Monterey 12.6
I tried doing the the USB port mapping but not with your supplied efi. When I boot with utportmap it hangs at something about activating the kext. I think it might be because of incorrect acpi patches so I will try what you suggested above tomorrow. I made a couple changes such as making both nvme controllers and nic set to built in and once I figure out how to get all USB ports mapped correctly I will post an efi. (Hopefully with the trackpad working as well) then maybe we all can tackle the cpus=1 quark.
Right, you mean UTBMap.kext? To use it you must also include the USBToolbox.kext. I don't think it has to do with incorrect ACPIs as otherwise the system won't boot. It's more than likely that. But yes we'll try to look into it afterwards (cpus=1) once you've done the USB ports & BT.
OG Nerd
I included the usbtoolbox.kext too but was right at end of day, I may have not added it to the config.plist tho. I will investigate it further tomorrow. Appreciate all the help!
Jo-Toku
I haven't seen any white noise, but I can also tell you I managed to install both Mojave and Catalina on the Atari VCS which uses an AMD APU with a Vega64 chip.
I made a guide for it here > https://www.tonymacx86.com/threads/guide-atari-vcs-2020-console.309903/
I think you should have a look at it because it is a more compatible setup for AMD based laptops, particularly if you want to get the graphics working.
I haven't updated it yet with the new no-gfx-spoof method as that was a recent addition from Opencore. But I think it should work.
Here is an example of the where the White Noise happen.
Specs on the laptop above are:
Omen 17 (2017-18)
CPU: I7 7700hq
GPU: RX 580 8GB
Memory: 16GB Ddr4 @ 2400
HHD: Nvme 256GB (From my Helios 500) Currently Mojave installed.
Wifi & BL: Fenvi m.2
As a Mojave Machine, is almost as perfect as you can ask for. But cant install any further
Edit: I have not applied any of your suggestions as I have been busy. However this video is context for several laptops and all with compatible Radeon Dedicated GPUs
zxc2689963
Welcome to help improve, I modified the device attributes of RX6600M in order to improve performance, and I tried the custom USB is invalid, I have to use the old GenericusbxHci. kext to complete Monterey startup, but all USB ports will fail, that is why BigSur is installed first
OG Nerd
Here is the odd thing about the USB ports in Monterey… I can plug in a usb dongle for wireless keyboard and mouse and it work, so I think usb 2 support is working, I just don’t think it works for usb 3.0 devices or higher… I am going to test that theory here in a few with usb 2.0 flash drive
Have you both looked at RyzenUSBfix? > https://github.com/AlGreyy/ryzenusbfix
This is from AlGreyy, who does the Ryzen patches for Monterey.
Another thing you could try is to use the XHC SSDTs from the B550 builds which should allow for all the ports to be used.
OG Nerd
The last efi you supplied (with suggested settings) produced a kernel panic at boot, so I reverted back to the old efi, I am trying the RyzenUSBFix now. Will post update
OG Nerd
Its taking forever to install developer tools. (So I can run the fixusb script)
OG Nerd
I tried to use the RyzenUSBFix but it asks for a access token if you use the second script and if you use the curl script it errors with 404 page not found, any ideas of the trick to get the script to work? Reading the instructions does not mention nothing of passwords or access tokens or that error.
That's outdated and it has those errors because XLNC doesn't use that GitHub account anymore so it has no repos in it.
OG Nerd
Do you by any chance know of a replacement that might help with the Legion 5 project?
Jo-Toku
I guess If we wanted a laptop with a 6600M with higher possibility to be hackintoshed we should have gotten this piece of overprice tech 🤣
EDit: Not, that price is silly and with that money may as well buy an M1 max
OG Nerd
Yeah I was about to say that lol... I guess the only plus to buying something like that is that you could max out ram and storage a lot cheaper than 16" Mac Pro BUT, I think for that price I would rather do the M1 Max and get the battery life and performance. I do think we will get the Legion 5 figured out in time. I had not had much time to mess with it since I got it, it has been installing developer tools until about 1:30PM my time. I will mess with it more tomorrow. The usbs worked in Big Sur, so there has to be a way to get them working.
Jo-Toku
Exactly why I love hackintoshes. My daily is a the Helios laptop with the Vega 56 and the Ryzen 7 2700. With multiple drive bays and upgrade options, 4 slots I can have 128GB or DDr4. Had 96 in it, but took 32GB and put it on the Legion 5. This level of tinkering is out of the question with macs now a days. I don't like buying video game consoles as computers (poking fun at Apple here).
If those Zbboks with the w6600m come are found cheap on ebay for let say 1100, ill pick up one, but not any time soon.
It might be a long shot but try the old GenericUSBXHCI kext.
On my other Intel hacks I normally also enable the SSDT-UIAC as well as the EC-USBX and/or USBInjectall or USBMap. That usually does the trick.
Right. I am thinking maybe because it is missing the cpus=1 setting? I didn't add that unfortunately.
That's the reason why I included SSDT-CPUR and SSDT-CPUR-5800H-2. Reason being is the ones marked 5800H should be technically correct because they do follow the settings based on the actual DSDT output - so if it crashes again you'll have to change the kernel quirks to the ones that work with your other Monterey build. Technically it shouldn't because I had based the main EFI settings on both of my working Monterey 12.4 builds.
However I would also be interested to know what that earlier kernel panic was about.
OG Nerd
I already tried that, I think it’s on the efi middleman supplied as well.
Ahhh…. That was something I didn’t even check, I will retry the efi with cpus=1 tomorrow!
