Very cool! Swapping out or a completely new, different machine? I'm sure we'll also see soon enough hahaA new project about to begin... What could it be?
As more parts arrive, the puzzle will begin to take shape...Very cool! Swapping out or a completely new, different machine? I'm sure we'll also see soon enough haha
A Thunderbolt add-in-card should work when devices are connected and powered before boot (i.e. no hotplug). The Asus ThunderboltEX4 is a Maple Ridge card whereas:What are folks' thoughts about using TB add in cards with motherboards that support them? Say, for example, the ASUS ThunderboltEX 4 with a mATX board with the appropriate internal header? I do not require hotplug. I don't know if I'm imagining things because I can't find it now, but I want to say that I've read somewhere that add in card support has been known to be problematic. Is that true?
This is such a first world problem, but I did not realize how much I appreciated the simplicity of having a displayport input on the motherboard and using a single thunderbolt cable to connect my TB4 dock/monitor to other machines. Barring the mATX/add in card option, the only other boards that I know of with onboard USB4/TB and DP input is Asus ProArt, which is certainly an option, but I've grown accustomed to having so much more free space available after going ITX. Again, first world problems
I'm not sure! The idea was to pair the add in card with the TUF B650M board, since it's got the thunderbolt header and the EX4 specifically lists the board as being compatible. Having never used one, I'm not sure if these headers are compatible with the previous-gen controllers. For my purposes, Titan Ridge has certainly been sufficient previously. That being said, what would be the benefit of going Titan Ridge over Maple? Better MacOS compatibility? Doing a quick search, I think availability may limit me to the newer Maple Ridge card hahaA Thunderbolt add-in-card should work when devices are connected and powered before boot (i.e. no hotplug). The Asus ThunderboltEX4 is a Maple Ridge card whereas:
Do you have the option to try EX3-TR?
- ThunderboltEX3 is Alpine Ridge
- ThunderboltEX3-TR is Titan Ridge
An even better option may be a flashed GC-Titan Ridge.
The new EX4 should be fine. Would be best to buy from somewhere that accepts easy returns in case that’s needed.I'm not sure! The idea was to pair the add in card with the TUF B650M board, since it's got the thunderbolt header and the EX4 specifically lists the board as being compatible. Having never used one, I'm not sure if these headers are compatible with the previous-gen controllers. For my purposes, Titan Ridge has certainly been sufficient previously. That being said, what would be the benefit of going Titan Ridge over Maple? Better MacOS compatibility? Doing a quick search, I think availability may limit me to the newer Maple Ridge card haha
Super good to hear, thanks for your input. If I can somehow stick with a small-ish case and have my single thunderbolt cable setup, I might be able to have my cake and eat it tooThe new EX4 should be fine. Would be best to buy from somewhere that accepts easy returns in case that’s needed.
Looks like the first new part is delivering today…Good teaser (for now, it looks like yet another regular PC) but… a delivery on Easter Monday?
The headers may not be compatible across manufacturers, but it is not necessary to use the header. One can mix and match, or use a Thunderbolt AIC is a card without header.I'm not sure! The idea was to pair the add in card with the TUF B650M board, since it's got the thunderbolt header and the EX4 specifically lists the board as being compatible. Having never used one, I'm not sure if these headers are compatible with the previous-gen controllers. For my purposes, Titan Ridge has certainly been sufficient previously. That being said, what would be the benefit of going Titan Ridge over Maple? Better MacOS compatibility? Doing a quick search, I think availability may limit me to the newer Maple Ridge card haha
how about the case? So excited for this build.The next two pieces of the puzzle...
View attachment 10328 View attachment 10329
Expected to arrive on Monday. Once you see it the gig will be up — the puzzle pieces will be nearly complete.how about the case? So excited for this build.
Yes!! We have a winner!TrueNAS build @CaseySJ ?
VoodooHDA?Hello evView attachment 10346eryone, I've seen only a few posts with my issue but I haven't really found a fix. I'm getting this log when I try and install Ventura. I'm brand new to everything so I apologize.
This is my hardware:
Processor AMD Ryzen 7 7700X 8-Core Processor, 4501 Mhz, 8 Core(s), 16 Logical Processor(s)
MotherBoard MSI B650 TOMAHAWK WIFI (MS-7D75)
