Probably, as it may not contain all the kexts you need in the Kexts folder; the SSDTs in the ACPI folder won’t be custom for your motherboard’s DSDT.aml; I can’t recall if there is a custom USB kext (probably not one compatible with Tahoe).
If it boots the system in to Sequoia it can be used from the EFI partition on your macOS drive, so you don’t need to use the USB installation drive.
