Hackintosh stuck at Blocked sign
blackrcses
51
USA (Eastern)
AMD Ryzen 7 7700X
Specs:
Ryzen 7 7700X
Radeon 570
SMbios: MacPro7,1
While that WD drive looks like it should be OK for use as a macOS drive, I would be a little wary as it doesn’t use the same Controller as the other main stream WD drives. They all use ‘Polaris’ controllers, whereas the SN730 uses a ‘20-82-00705-A2 Triton MP28’ controller. The SN730 is commonly seen in OEM laptops, i.e. it is less expensive and can be rebranded by Lenovo, HP etc.
Bit definitely worth a try.
I am actually losing it, I tried it with both the online and offline, tried uninstalling my M470 PRO, disconnecting every device except for ethernet, displayport, keyboard, mouse, and usb but it still gets stuck at About 12 mins Remaining
I DID SOME DIGGING AND I FOUND THIS AND IT WORKED. “
  1. Head to your config. plist and change the following if not
    already: Boot -> Quirks DisableVariableWrite = False
    Misc -> Security ExposeSensitiveData = At least 0x1 or
    higher (hex) or 1 (decimal) NVRAM LegacyOverwrite =
    True WriteFlash = True
  2. With in your efi, add the following efi folders to the drivers if not already: OpenVariableRuntimeDxe.efi driver OpenRuntime.efi driver (this is needed for proper sleep, shutdown and other services to work correctly) Head to any plist editor (preferably ProperTree) and conduct a OC Snapshot (Cmd+shift+R). Head to UEFI->Drivers and make sure the two efi files are enabled to load early and that OpenVariableRuntimeDxe.efi is placed before OpenRuntine.efi in your config.”
It
It just needed a emulated nvram bc amd native nvram’s are messy.
Reactions: Edhawk
