Need a lot of help
And they are enabled and working?
Der_Slime
Yes of curse, I mean if they didn’t work, the whole UI will have bugged Symbols 😅
Just checking (y) Did you try the suggestion of changing the format in Audio Midi?
Der_Slime
I tried serveral times to change the format but northing improves the quality of the sound.
and with the ui bug, is it necessary to have Nvidia cuda (I don’t know exactly how it called) installed?
Der_Slime
Well I tried in the last days some other Voodoohda versions and nothing will work :/ is it possible to get a better result when I change my SMbios? Currently I have the iMacpro 1.1
Der_Slime
Well the Bug with the UI is only a mouse bug, I tried another mouse and now it work perfect. But I still have the problem with the Sound :(
Gigamaxx
Can you run a Geekbench Compute bench and post a screenshot result?
