Hello, I'm trying to install macOS Sonoma using this guide, but I can't get it to work. What happens to me is that the installer never fills the bar of this screen; it constantly reboots around this:
Then it shows me the following screen, but it doesn't fill either and reboots again around that same advance:
And finally, it shows me this other screen:
The only thing I can do is try to install it again, but it is an endless cycle of installation attempts that never ends. Does someone know what to do in this case?
I already enabled the SVM inside my BIOS, and I'm using:
  • Windows 10 Pro
  • AMD Ryzen 9 9950X 16-Core Processor 4.30 GHz
  • 96 GB RAM
  • MOB MSI MPG X870E Carbon WiFi
  • NVIDIA GeForce RTX 4080
  • SSD SSD Kingston Fury Renegade 2 TB (Kingston SFYRD2000G)
  • HHD 3.6 TB ST4000DM004-2CV104
I already tried other internet guides, but got worse problems: infinite reboots during installation, until I got an error screen. On those other guides, I needed to modify the macOS.vmx file and add some lines to be able to start the installation, but as this guide said, when trying this guide, I started from zero, uninstalling the unlocker by using the file win-uninstall.cmd with admin privileges, deleting the previous VMware Workstation, and installing again with the link of this guide, and using the Unlocker provided inside this guide.
Extras:
  • I did point 8 about adding:
    • bcdedit /set hypervisorlaunchtype off
    • reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios\HypervisorEnforcedCodeIntegrityā€ /v ā€œEnabledā€ /t REG_DWORD /d 0 /f
  • I have tried four different ISOs (including the Sonoma one you put in this guide), but I still get the same issue with any of them.
  • I used the OPENCORE 16-core setup provided in this post and set the Hard Disk to SATA 0:0.
  • The CD/DVD is on SATA 0:1.
  • The Hard Disk 2 is on SATA 0:2.
  • The lines inside my nacOS.vmx file were okay with a 16 as value.
    • numvcpus = "16"
    • cpuid.coresPerSocket = "16"
  • Windows 10 Pro
  • 96 GB RAM
View attachment 18373View attachment 18374
Extras:
    • numvcpus = "16"
Hello. Try to create a virtual machine from the very beginning and use it specifically for 4 core AMD.
This version only works with Ryzen processors with 4 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 4 cores
Thanks for your answer. Unfortunately, even doing what you said, I got the same problem.
I captured these screens. I don't know if they could help solve or find the problem:
vmware_Hej2dsuoiW.pngvmware_TrHTNXTGvy.pngvmware_6vA6JX41BU.pngvmware_Fe4CqOslfT.pngvmware_1FPJhcKV6B.pngvmware_r89JZFLx4z.pngvmware_Nvm5q6TcYo.png
It's always the same situation.
1. I start installing, but this screen never fills the charge bar; it constantly reboots at this same point:
2. I got the screen with all those white letters that I showed at the beginning.
3. I got the following screen, but without doing anything or selecting the third option, it continues.
4. I got stuck again on a load bar, but this time at the following screen, and again, it never passes that point.
5. Again, point two, the screen with all those white letters that I showed at the beginning.
6. Again, point 3, and it's an infinite cycle.
VMWare Workstation Pro 25.0.0.24995812, macOS Tahoe Beta (25B5072a) handmade iso from official InstallAssistant, macOS_Opencore_Tahoe_1.0.5_8_cores from this topic. A bit luggish but fun to work with.
Good news!!!
Tahoe is now working on VMWare!!!
I finally got Tahoe working on VMWare, and if you want to download and test it too, here are the necessary files:
VMWare disk Image File AMD 8 cores (Tahoe Version) :
macOS_Opencore_Tahoe_1.0.5_8_cores.zip: https://drive.google.com/uc?export=download&id=1rcdkbnHfn0uKmqXru236U5_dFADH-rg9
Thank you very much! This just worked on my Ryzen 7-8700G with the latest 26.1 Tahoe iso (from macplanete.com) ! Definitely need the "Tahoe" Opencore vmdk to boot properly.
Hello! First post Here!
Just wanted to tell everyone how I fixed no internet in Tahoe VM on VMware:
1. Install the vmware tools from reddit (no more avaiable downloads on the website, my version is Darwin 13.0);
2: Boot the vm, the opened Virtual Network Editor from Edit tab;
3: Press on edit settings, VMnet0 finally appears;
4: Select Bridged, Bridged to: "yourinternetcard PCIe GBE", then press apply!
Hope this is helpful for someone, I actually don't know how to use wifi because I'm on a ethernet-only setup. If you have problems it might help to check with WIN+R, ncpa.cpl,
select VMnet1 and VMnet8 and allow WMware bridging protocol by opening the Proprieties tab.
(sorry for my bad english, it's not my first lang).
A gray screen after install about 5 minutes and restart.
And so on.
Strangely.
Since the same virtual machine I put this OS and everything was fine. The same canonicalization on settings and paths.
I forgot about the VMware patch and upgraded to workstation pro 252H and it broke the VM. I had to uninstall and reinstall Workstation Pro 17.6.3 and was able to recover.
FYI just in case you are considering an upgrade.
Hi @tucano2000
I hope you're doing well
Is there possibly a VMWare disk Image File AMD 8 cores (Tahoe Version) but for 4 cores?
Thank you in advance!
If you read the 1st post in this thread, there is a link to the VMWare Disk Image file for a 4-core AMD CPU in section 3.
Hi @Edhawk is it ok for Tahoe?
Thank you
It worked with the Tahoe beta, so I expect it still works with the main GM version of Tahoe.
By the way I forgot to tell that thanks to you guys using this guide from the first page I was able to sucessfully install Sequoia.
But when I'm trying to install Tahoe If I'm using same vmware disk image with Tahoe I'm getting a "the firmware encountered an unexpected exception vmware" error from VMware app. The VMWare image is being mounted into data 0:0, then I add data 0:2 for the 80 GB hard drive. And then I add CD/DVD for Tahoe iso and I'm getting that error immediately when powering up the Tahoe virtual machine, leave alone that I can't get to the boot installation screen.
Good news!!!
Tahoe.iso
The first file is a WinRAR executable to automatically extract all files. You do not need to have WinRAR installed.
Part 1 : https://drive.google.com/uc?export=download&id=1aI7UGkS4Y7Dp5N1zPBpZ74WCeMgiT-H1
Part 2 : https://drive.google.com/uc?export=download&id=1o57Ut90CvLs9UwquIF300s3n5G21O7mV
Part 3 : https://drive.google.com/uc?export=download&id=1MJVM6utIHdL9a-dkZB1F9dpxMOqFAC9w
Part 4 : https://drive.google.com/uc?export=download&id=1LHAFsVtc31TV6i4Wpu0dfcdiy0NM9Hhv
Part 5 : https://drive.google.com/uc?export=download&id=1WUlXxsN2UcfvyaOnrLdQE5k1dSWJMb_2
Part 6 : https://drive.google.com/uc?export=download&id=1I1bl_Kbp7clI1S5Q3oQugRx0piar0Rcj
Part 7 : https://drive.google.com/uc?export=download&id=1qBSXiKriFht5a1HE984XSa2r-0lM64bB
Part 8 : https://drive.google.com/uc?export=download&id=1Bq_NAvfYO_XF_LtXesTzhNmV4UQbkv-6
Part 9 : https://drive.google.com/uc?export=download&id=1ic34FtCBp7yWc9Keis1e7FkXNQWdOaLT
Extract the files from Tahoe.iso and the Opencore 1.05 vmware disk image file modified for Tahoe. (macOS_Opencore_Tahoe_1.0.5_8_cores.vmdk)
You need to set 8 cores in the VMWare configuration, which contains the number of cores for the CPU. (only AMD processors yet)
During installation, the emulation is very slow and it is difficult to even control the mouse, click on buttons, and fill in fields, but with a little patience, it will work. After installation, this slowness does not occur in the same way, and if you install VMWare Tools, the fluidity improves a little, making macos tahoe usable for certain tasks.
The new Tahoe application menu is slow to load and display applications.
Right at the end of the installation, before the Mac desktop appears, the installer freezes and shows a white screen. I restarted the Mac and it loaded again with the login screen and the installation already complete.
I had to disable vmhide.kext because it wasn't working. I updated to version 2.0 and Tahoe would no longer start. Finally, I applied the iCloud patches that allow you to use iServices (login to Apple services such as iCloud, Apple Store, etc.).
Keep in mind that it is still a beta version, so problems will always arise.
Good luck.
I downloaded all from the files your post and followed your instructions but afther the installation and first boot I got stuck here:
is been there for almost 6 hours, what can I do? I dont know even to diag what is happening.
previously I had Sonoma working on another VM in the same Vmware. I created a new VM from scratch following your post intructions.
to clarify, this happends afther the installation process on fist boot.
regards!
Add verbose boot argument (-v) to the config.plist, so the cause of the kernel panic is shown instead of the Apple logo and progress bar. Depending on where the text stops will give a better idea of the cause and possible fix for the kernel panic.
Does anyone know if the patch will still work with VMware Workstation 25H2?
Thank you!
I dont know what I did, but I manage to installed and it is working. Althought it is slowwww :D
Have you read through the 1st/2nd pages of the thread, as they contain fixes for common issues such as the macOS VM being slow.
