zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Hello everyone, the Monterey kernel panic problem has been solved for AMD R7 5800H notebook installation. It is a great thing that the CPU can now run on eight cores. Thank you guys very much.Thank them for discovering the problem and providing kernel patches @ExtremeX@Visual
Brand: Lenovo
Problems solved:
3. Monitor brightness can be adjusted only in Ventura
Unresolved issues:
Hi, I am new; I have the same model, R7000P 2021A, with Ryzen 5800H and 6600M, intel 210 WiFi. On the Ventura installer with boot-arg -v, the boot process goes on, but I get a black screen after verbose using your EFI. Any Idea on how to fix it?
Boot args used:
-v keepsyms=1 debug=0x100 -vi2c-force-polling agdpmod=pikera
A video showing the problem: https://drive.google.com/file/d/1caR_zViXd5ksMcUXpUrWLoMF_GROsfil/view?usp=sharing
Boot args used:
The problem was solved by installing BigSur using the aforementioned EFI, installing it without any issues, then updating itwl Kext to enable WiFi and update to Ventura. Then again update the WiFi Kext to support Ventura.
Thanks to all the contributors for enabling this device to work flawlessly.
@Shaneee Thanks for your input. I'm pretty sure it would fix it since that's where it panics, but I'm guessing that it's not worth the time.
On another note, this seems like what we need! (Image)
@zty199 Please try this EFI.
@craighazan Do you also have this laptop? If so can you test it?
- ExtremeXT
I'm getting the same panic on a GenMachine Ren5000, 5700U. Trying to install Sonoma but not getting very far!.
So after reading through this thread and testing some of the EFI's, I still don't seem to be getting anywhere. Edhawk kindly put together an EFI for me to try, it contains the patches from Visual, attached below. The purpose of this build is a case mod for a Nintendo GameCube, any advice would be appreciated.
I'm attempting to install Sonoma, should I install Monterey instead?.
Your SSDT-CPUR has the wrong number of CPU cores, you should remove some and leave only 16 cores
Reactions: craighazan
Thanks for the tip, I remember reading about that somewhere within this thread. so my first four patches should be;
B8100000 0000
BA100000 0000
BA100000 0090
BA100000 00
instead of;
B8080000 0000
BA080000 0000
BA080000 0090
BA080000 00
And will Sonoma work, or should I install Monterey?. TIA
B8100000 0000
BA100000 0000
BA100000 0090
BA100000 00
instead of;
B8080000 0000
BA080000 0000
BA080000 0090
BA080000 00
No, your kernel patch is 8 correct, your SSDT-CPUR is not right, there are too many cores do not know whether it has an impact, try the SSDT-CPUR I provide屏幕截图 2024-01-06 173935.png
No, your kernel patch is 8 correct, your SSDT-CPUR is not right, there are too many cores do not know whether it has an impact, try the SSDT-CPUR I provided.
Thanks for your help, unfortunately I’m still getting this kp.
Try using parameter CPUS=1
We're all good, I established that CPUR wasn't needed for the Ren5000, the chipset isn't a 500 series board. But thanks for the help.
Also waiting for Zen3+ 6800h laptop
Do you have the same brand with mine?
If your laptop is the same with mine, you can go to this thread and work together with us
Try this revised EFI-10 folder. Don't change anything, just post a photo of the verbose text if it kernel panics.
I checked the ACPI SSDT's and patches in your current EFI, and these seem to be OK. Same with Drivers, Tools and Resources folders.
I have removed some kexts, USB, Bluetooth, WiFi and TSC.
  1. The USB kexts are not doing anything helpful, as they don't include a custom USB configuration, just the empty 'Default' kext.
  2. The Bluetooth and WiFi kext removal is just a precaution as some recent releases of macOS have KP'd when these are present during the installation. So I thought it would be good to try installing Monterey without them present in the OC setup.
  3. I have replaced the AmdTscSync.kext with an alternative TSC kext (ForgedInvariant.kext).
Made a couple of minor changes to the config, as well as the kext changes above.
Let me know how you get on.
Still get a forbidden icon after here.
How far did you get with creating a custom USB kext, in Windows using the USBToolBox Tool?
