zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Tested with Ventura 13.4.1 and 13.5, kext enables all USB ports, with both controllers enabled (kext is an upgrade from GenericUSBXHCI).
Can you share EFI and whether it can be used on MacOS Sonoma?
Yes, but it didn't work, and I couldn't solve it with limited ability
Do you know if your WIFI+BT external dongle works with any version of macOS? Because some dongles don't work (I know that the ones with the CSR8510 A10 chip works).
Hey friends, I can use all USB ports on macOS 14 Sonoma beta4, I need to change the configuration as shown in the picture, but I can't drive Bluetooth, can anyone help take a look.View attachment 11587View attachment 11595
Get some error using your kext work for legion 7i with 6800h+6600m. Stuck at IOPCIConfigurator: configurate kIOPCIEnumeration WaitTime is 900
USB Kext solution:
Tested with Ventura 13.4.1 and 13.5, kext enables all USB ports, with both controllers enabled (kext is an fork/update from GenericUSBXHCI).
Can you modify this based on my EFI, thanks
My laptop is the 6 core processor version, you will need to adjust the kernel patches.
And it's no use using my EFI as a reference to try to solve your problem with bluetooth.
My laptop is https://www.lenovo.com/us/en/p/lapt...0000us?orgRef=https%3A%2F%2Fwww.google.com%2F
What kind of adjust do I need to adjust to kernel patches?
Thanks
Hello, everyone I have solved the efi of 5800h, and now the Bluetooth can also be used normally. This is my efi, please change the serial number and other data by yourself截屏2023-08-09 02.11.48.png
Reactions: zljjjjjj
你的机型比较新
cpu是6800
需要找找看有没有同款cpu的efi
然后找到对应的参数进行修改才行
目前我只清楚5600和5800的参数;所以帮不上多大忙
6800和5800CPU内核应该是同一代吧,主要区别在GPU,我把igpu关了,CPU数据应该不需要修改太多吧,我不是太清楚
