Metal 6950XT Shaneee vs ...ok, and now could make the test with it for Metal, then we can have an overall view of the graphic performances
GB6: 235203 vs 205060
GB5: 207587 vs 199226
6950XT, 6900XTXH: spoof 6900(XT): BF730000so I did scroll up, and I note that the spoofed device ID "BF73000" is the same for both the 6900XT and the 6650XT.
6650XT: spoof 6600(XT): FF730000
My Fractal North case is arriving sometime this weekend and I will start building my long delayed 7950X / X670E Creator build. I had hoped that the 7900XTX would be natively supported by the time I started building this 3rd (and for the time being final) Hackintosh, but so far we are only holding on to fumes of hope regarding the W7900XT. my current plan is to install the 6900XT Ultimate into the 670E Creator build and swap out the 6650XT into the older 5950X build.
it works also for poor not XXD cpusI want one of those Ryzen 7000X6D processors! No, I want 10 of them...![]()
OMG, maybe Germany has the X8D. We need to check all over the world…View attachment 10511
@CaseySJ yours is newer than mine
ROG CROSSHAIR X670E GENE
Formata dall'unione del DNA ROG con un enzima SFF, ROG Crosshair X670E Gene è una potenza mATX che permette di avere tutto. Con un'erogazione di potenza e dissipatori potenziati, offre una porzione abbondante di processori AMD Ryzen™ serie 7000, oltre a una miscela digeribile di PCIe 5.0, DDR5...rog.asus.com
also in Kansas you have a new shining 7D cpu new firmware as in Italy and in others world area
I have updated my hero but I can't reach the same 5200 Mhz for 4 dimm slot
"only" 4800 Mhz as the previous bioses
7950xare you running an X3D CPU or non-3D?
madness, new F5b bios Gigabyte , huge MT score gainsView attachment 10534
