it's thermalright axp-120 x67 , a topdown cooler for ITX formWhat CPU cooler are you using?
i wish i had kept a backup copy of the older BIOS. i am not an overclocker tho.. so I guess I don't lose anything with the new BIOS.
my X670E Hero is running BIOS 0805 and is rock solid.
latest beta updates agesa (and this could be a great improvement ) but also due its voltage restrictions it limits the change to have memory DIMM @ greater frequency than the ones AMD suggests
lastest gigabyte bios f5b break my onboard audio and wake on usb![]()
ASUS is not responsible for direct, special, incidental or consequential damages resulting from using this beta BIOS. Very bad customer experience.I have Asus ROG CROSSHAIR X670E EXTREME - a $1000+ motherboard.. and Asus only released a BETA bios with a fix to prevent an issue which could result in CPU & motherboard both being fried to death... with a note sayingASUS is not responsible for direct, special, incidental or consequential damages resulting from using this beta BIOS. Very bad customer experience.
Which one do you think Asus will give more priority: The board that has been sold in the hundred of thousands and is a support nightmare or the super expensive board that has been only sold a few hundred to a few thousands and is fairly manageable in case of issues?I have Asus ROG CROSSHAIR X670E EXTREME - a $1000+ motherboard.. and Asus only released a BETA bios with a fix to prevent an issue which could result in CPU & motherboard both being fried to death...
I am fully aware that they do not care.. about both groups of peopleWhich one do you think Asus will give more priority: The board that has been sold in the hundred of thousands and is a support nightmare or the super expensive board that has been only sold a few hundred to a few thousands and is fairly manageable in case of issues?
Hello guys. I have a B650M AORUS Elite AX and a 7700x is there a base EFI to just get me booted into Ventura ? Thanks.
Gigabyte B650M Aorus PRO AX (rev. 1.0) EFI - Adaptable to Gigabyte B650 boards
** This is just a preliminary version for this Gigabyte AM5 motherboard that could be adapted to other boards Parts used in my build: Gigabyte B650M Aorus PRO AX (rev. 1.0) - bios F4b (F4 was released, I need to update) AMD Ryzen 9 7900X 12-core 24-thread processor TBD Radeon RX 6xxx GPU ( I...forum.amd-osx.com
Gigabyte B650 Aorus Elite AX, Ryzen 7 7700x, RX6600, Monterey, Opencore 0.8.8
Spec: Gigabyte B650 Aorus Elite AX (F3 Bios) Ryzen 7 - 7700x Western Digital SN850x 1tb NVME ssd 2x Western Digital SN770 2tb NVME ssd Radeon RX6600 XT 32gb Corsair 5600 Ram This board has a major issue, there is a decompile error when running ssdttime. This prevents Mac OS X from booting. The...forum.amd-osx.com
I have a Broadcom WiFi 6 module that hasn’t worked previously, but I’m tempted to try again with Ventura 13.4 public beta.hey guys I love my Fenvi T919 but I wonder if there is a way to have Wifi 6E and BT 5.0 while maintaining airdrop, handoff, and continuity,
is this possible? what WiFi / BT adapter is there that meets both above requirements?
You can check AirportBrcmNIC.kext's Info.plist to see the supported device IDs.I have a Broadcom WiFi 6 module that hasn’t worked previously, but I’m tempted to try again with Ventura 13.4 public beta.
Very nice -- is TrulySpinach still maintaining the GitHub project? Hopefully the PR will be merged soon.thanks @Lorys89 and @mbarbierato
now it is possible to have "fan" also with AM5 chipsets and AMD power Gadget app
A PR on AMD Power gadget GitHub will be done as soon as possible
Improvement - added AM5 chipset fan reading support
Hello Community, today I was a bit free and I decided to fulfill a wish of dear friend @fabiosun and therefore I implemented with the help of my dev friend @mbarbierato the reading of the fans for the am5 chipset on the https://github.com/trulyspinach/SMCAMDProcessor project. AMDRyzenCPUPowerMana...www.macos86.it
