Awesome!! Could you please share the kext? :D
Because it was provided to me via private message, I might not be at liberty to publish it. Perhaps @Lorys89 could provide a download link.
Reactions: Lorys89
Reactions: etorix
@CaseySJ
Devs are still working to solve some problems in I211 ethernet kext (in Monterey doesn't work) and also if you have an ethernet card without a cable connected you could see Self ip Assignment yellow icon on it (and different ip family and router)
@CaseySJ
My testing was done in Monterey with the kext provided by @Lorys89 — so it is good to see the positive result there.
Reactions: ExtremeXT
Reactions: CaseySJ
I only had to add e1000=0. It sure if SIP is enabled or disabled though…
if I add the bootargs Monterey Boots fine but no ethernet cards exposed in my case, I am using the same sip condition I have in ventura
I am reinstalling Monterey..I am too much curious to see this working also here :)
Reactions: CaseySJ
ethernet and ethernet 3 are i211 ethernets
Ethernet 3 has no cable inserted
ethernet 2 is aquantia (Ventura 13.2 (a) )
this is in Monterey 12.6.1
same behaviour of Ventura OS
it works well with 2 ethernets cable on
Self assignment if one cable is off
No need of e1000 bootarg in both OS
Sip enabled or disabled is the same
Reactions: Lorys89 and CaseySJ
While others are buying the new RDNA 3 GPUs, I finally got myself a 6650 XT from MSI on 36% discount at 345 euros, should arrive in time for Christmas :)
Seems there an hardware bug on the rx radeon 7900
Yesterday I tried to make my PowerColor RX 7900 XTX work in Monterey 12.6.2. I tried following this guide as much as I could but the PCI mapping is very different and I probably made a mistake somewhere along the DSDT creation, I got lost. Just works with the framebuffer so no hardware acceleration, sadly.
I'll try to post the info/pics/process to see if someone can help me figure it out.
PS: Not even sure there is any support "driver-wise" for this card in Monterey.
Regarding the PowerColor RX 7900 XTX:
1. Upgraded to Ventura (from Monterey).
2. Here's what gfxutil shows:
gfxutil.pngs:
3. Here's what IORegistryExplorer shows:
4. Here's what MS Windows' Device Manager shows:
5. Here's what I added under Device Properties in the config.plist:
Attached the "experimental SSDT-BRG0" dsl. Sadly, not working and therefore the GUI is not showing up. I lack knowledge on this.
Any help is appreciated :D
Are you upgrading an existing system or contemplating a shiny new AM5?
s:
"IOPP" is a pci-bridge
So it seems the device ID = 0x744C for the 7900 XTX. We'll have to keep a lookout for any mention of this in new versions of macOS.
Unfortunately, without support from AMD and Apple, it won't be possible to get acceleration working.
I am still holding on to the hope that this will happen, and hopefully in 1H23.
I'm upgrading the system in my signature from the old RX 550. I know that the CPU will bottleneck performance, but I'll probably upgrade to the lower end AM5 models when they release.
I saw this:
if you want to check it out as well. Around minute 2:47
I don't speak nor understand russian but the video seemed interesting regarding the RX 7900 XT on Ventura
