My mistake -- I thought you were using Clover. If you're using OpenCore then the screenshot is correct.
Let's try once more, but with pci=0x03 that will enable both _IOLog (dmesg) and kprintf (system log).@CaseySJ pci=0x02 ths hangs my system in early stage
added two new patches and I have the same result
bootlog.txt always the same hereLet's try once more, but with pci=0x03 that will enable both _IOLog (dmesg) and kprintf (system log).
Apologies @mariettosun I made a mistake while sipping coffee by the fireplace...bootlog.txt always the same here
dmesg output could be useful?
Yes -- that is a problem
# Packet 2
<== AppleEthernetAquantiaAqtion::interrupt_msi_handler
==> AppleEthernetAquantiaAqtion::interrupt_msi_handler index=0
==> AppleEthernetAquantiaAqtion::rx_pkt_queue
==> AppleEthernetAquantiaAqtion::allocate_mbuf
<== AppleEthernetAquantiaAqtion::allocate_mbuf mbuf=<private>
reg_put32(<private>, 0x00000002)
Flushing input queue.
<== AppleEthernetAquantiaAqtion::rx_pkt_queue
reg_put32(<private>, 0x00000001)
# Packet 3
reg_put32(<private>, 0x00000003)
# Packet 4
reg_put32(<private>, 0x00000004)
Problem Found:@CaseySJ maybe is it for this?
Let me send you modified config.plist in Private Message...@CaseySJ a correct ip is now there but system does not surf internet
first find patch is not found in my log as before
Awesome. We need as many testers as we can get!Hohoho looks like I just got a whole bunch of test to do! I’ll get back to you guys when I get my access to rig once again. Truly amazing work to all of you!!!
Thank you — this is the first independent confirmation!!@CaseySJ your config did the job
first boot it reboots after few verbose lines
then it starts correctly and Aquantia is working well
Tested a cycle of Sleep/wake
It works perfectly (as before in my system)
So now, in MSI trx40 Pro work two internal i211 lan with new kext of @mbarbierato dev and Aquantia PCIE card with your patches
Here, but unfortunately it's not open source.Thank you — this is the first independent confirmation!!
Can you post a link to the i211 driver?
