PoMpIs
Well-known member
Are you sure it actually boots slower? It should boot faster... I'll look at the patch when I get back home, I wasn't sure if it's still needed on this mobo.
Yes, a few seconds slower to boot if it is, but very little...
For the rest everything works... and especially the audio, it's perfect!!
Thank you very much to all 🤗
  • opencore-2022-11-19-151810.txt
fabiosun
If now you are using a release (not debug Opencore version) put target to 3
it is not useful to post a debug with Opencore release data (few data to read in it)
PoMpIs
Well-known member
If I have already changed it, but each restart generates a TXT in the EFI 😄
A curiosity....
Hackintool tells me I'm using clover 🤣
fabiosun
post only config.plist @PoMpIs
fabiosun
@PoMpIs try this before reset your Nvram
  • config.plist.zip
drmeatball
Going to try jumping in.. I've built plenty of intel hacks but this is first AMD hack. Have zero issues reformatting over and over to get us to a workable state.
That being said, I'm starting from square one (maybe that's useful in some way?) so is the Dortania AMD info enough to get the ball rolling - using these updated 087 opencores. Is there anything AMD specific beyond the Dortania guide (and everything here) I should be aware of?
Asrock Steel Legend, 7950x
!TYTYTY!
!TYTYTY!
You'll need a custom version of SSDT-CPUR, an MmioWhitelist and an USBToolBox USB map. I can help with all of these if you send a SysReport log and your EFI.
Could you try making it check for ExtFamily=A OR ExtFamily=8 when you get back?
C:
if (CpuInfo->Family == 0xF && (CpuInfo->ExtFamily == 0xA || CpuInfo->ExtFamily == 0x8)) {
** OpenCore Beta Test Build #2 **
  • OpenCore.efi has been recompiled with this condition: ExtFamily >= 8
  • Both release-mode and debug-mode builds are attached below
  • For faster boot up, release-mode build may be used
  • For providing helpful debug logs, the debug-mode build should be used with debug target set to 0x67
    • Then OpenCore log file will be created in root folder of EFI partition
    • We really want OpenCore debug log files from as many different AMD and Intel processors as possible
C:
  // For AMD Family F and ExtFamily >= 8
  if (CpuInfo->Family == 0xF && CpuInfo->ExtFamily >= 0x8) {
      DEBUG ((DEBUG_INFO, "OCAK: Setting FSB and TSC for Family F and ExtFamily >= 8\n"));
    busFreqValue    = CpuInfo->FSBFrequency;
        busFCvtt2nValue = DivU64x64Remainder ((1000000000ULL << 32), busFreqValue, NULL);
        busFCvtn2tValue = DivU64x64Remainder(((1000000000ULL) << 32), busFCvtt2nValue, NULL);
        tscFreqValue    = CpuInfo->CPUFrequency;
        tscFCvtt2nValue = DivU64x64Remainder ((1000000000ULL << 32), tscFreqValue, NULL);
        tscFCvtn2tValue = DivU64x64Remainder(((1000000000ULL)  << 32), tscFCvtt2nValue, NULL);
  • DEBUG.zip
  • RELEASE.zip
Tested..
It seems to start a little slower... but it works fine..
Now this appears in the LOG:
I get an ¿error? on DP68... when removing the patch you did for the x670e-f
Those ACPI errors in the macOS system log are actually okay! Well, technically it suggests sloppy work by the board/ACPI vendor, but for macOS it should be okay.
backinblackx86
Hello, I have time today to test my system out. I have a 7950x with the asus x670e-extreme. Where shall I start?
backinblackx86
Hello, I currently have Ubuntu Linux 22.10 Kernel 6.0.9 installed. How do I create the SysReport log, by booting a debug version of OpenCore?
Make an EFI with the Dortania guide, make sure you're using the DEBUG version of OpenCore and the SysReport quirk is enabled (use CTRL + F). Then try booting, it'll fail 100%, but it'll create a log and a SysReport. Zip the SysReport folder and the .txt file and send it here along with your EFI.
There's a helpful table of CPUIDs on WikiChip (not Wikipedia). Let me see if I can find the AMD version of this table.
  • We can see that Family 0xF is also used by some Intel parts, but their ExtFamily is 0x0.
There's a helpful table of CPUIDs on Wikipedia. Let me see if I can find the AMD version of this table.
Looks like Intel's ExtFamily is always 0, can't we make it check for ExtFamily != 0 then?
