@CaseySJ The 2 byte patch doesn't work for an MSI user, but the 4 byte one which you tested works fine, I guess we'll merge that one. Waiting for one more MSI tester.
EDIT: Another user got it working... You should try it too.
Reactions: PoMpIs and CaseySJ
Sounds good. Just got back from lunch.
Reactions: ExtremeXT
For anyone wondering:
  • Method 3 kernel patch allows 8-bit extended tag fields (8b ETFs) to be enabled, and only disables 10-bit ETFs (10b).
  • Boot Argument pci=0x8000000 disables both 8-bit and 10-bit ETFs.
It works!!
Feel free to make pull request on the AMD_Vanilla GitHub with any final versions of patches/boot args used and I'll merge it. Also speak to @alyxferrari about adding it to the FAQ also if required.
Again awesome work guys :D
Note to Self:
  • Thunderbolt implementation on this AM5 board is quirky
  • If Thunderbolt is disabled in BIOS, remember to disable the associated Thunderbolt SSDT, otherwise WiFi or any card installed in spare PCI slot will not work
  • If Thunderbolt is enabled in BIOS, remember to enable the associated Thunderbolt SSDT, otherwise Ventura will not boot
  • Sleep, Wake, Reboot, and Shutdown work when Thunderbolt is disabled in BIOS, but do not currently work when Thunderbolt is enabled (I'll look into this later)
Reactions: fabiosun and etorix
I have used the patch and the boot arg to boot Ventura. I installed Ventura on an M.2 NVME drive using an intel iMac, then copying my EFI on to the EFI partition. My Asus Strip X670E-F with the Rysen 7950 boots into Ventura, I log in, then after about two minutes, it freezes. I repeated the process using a 2.5 inch SATA SSD and it is rock stable. I an unsure if this is related to the PCI issue or not. I was running Big Sur on a M.2 NVME drive and it was also very stable. Any advice out there?
Reactions: PoMpIs
Please note that we should use either the boot argument or the kernel patches, but not both. The latest kernel patch is Method 3 (see my post directly above).
  • Love
Reactions: Galve2000
Here's an MSI motherboard running Ventura from a tester, confirmed that it's working here too.
I'm glad to see the exciting work. Does it mean that the problem on MSI's motherboard on am4 has been solved?:D
Tried parallel approach of adding device-id to DeviceProperties with my Aquantia but still gives me KP. uwu
@CaseySJ Should I send the PR with the 4 byte patch to the repo?
@ExtremeXT why a patches is advisable against the use of a bootarg 1revenger found in the kext code?
I mean is not more solid a bootarg if kext you patch change with an os upgrade?
Only to understand well
Thank you
Thank you
New kext patch should work for newer macOS versions. It's preferred because Zen 4 and MSI only have problems with the 10 bit tags, but the boot arg also disables the 8 bit tags which don't have to be disabled.
In the faq and also in amd vanilla GitHub repo should be left a track also of that boot arg in my opinion
Thank you
Are you referring to boot argument pci=0x8000000? We discovered it here:
