Hi @eduard0,G'day John,
I'm having a bit of a weird one. Upgrading from 0.7.9 to any of the EFIs here works fine on Big Sur (11.6) after I've added my necessary changes (ROM, Airport kext, etc), but when I try to upgrade to Monterey, it either totally crashes the installer inside of Big Sur, or hangs with the Apple logo and no progress bar on reboot. I've tried every EFI version from 0.8.0 to 0.8.4 here and the same happens, and I've re-downloaded the Monterey .pkg multiple times now. Previously I was using one of the EFIs from AudioGod's X570 ROG Strix thread.
Any ideas? I've attached the latest version of my EFI (0.8.1) in case I've done something boneheaded.
It is indeed in there.Hi @eduard0,
Have you tried adding AppleMCEReporterDisabler.kext to your build? It is a vital kext to add to boot Monterey 12.4 and beyond.
Okay @eduard0, it looks like you're missing a fair amount of necessary SSDTs in your build, namely:It is indeed in there.
I would remove the AMD Power Gadget Kexts. They are different for Ventura and the EFI has all the changes for Ventura.Hi @eduard0,
Thatās one of Johnās EFIs from this thread with my Generic data filled out and the appropriate core count.Okay @eduard0, it looks like you're missing a fair amount of necessary SSDTs in your build, namely:
SSDT-CPUR.aml
SSDT-EC.aml
How does your USB ports fair? If they're not working fully you may also need SSDT-XHC0-TO-XHC or PTXH-TO-XHC2-NO-PO9-10-11 renames.
I also noticed you never installed SMCAMDProcessor.kext after AMDRyzenCPUPowerManagement.kext.
And you added the wrong agdpmod setting and haven't populated the device tree for the AMD GPU. It should be set to agdpmod=pikera for RX6800, NOT agdpmod=ignore as it is right now.
You also need these device properties for your RX6800XT.
Thanks for taking the time to compile these EFIs. For some reason I keep getting stuck at "12 minutes remaining". Was this something you experienced and do I just need to wait it out?Ventura beta 11 works with the 0.8.5 EFI.
Thanks, I have Ventura Beta 11 installed. Running smoothly.Try this site for 9, 10, or 11. https://mrmacintosh.com/macos-ventura-13-full-installer-database-download-directly-from-apple/
I use the BCM94360NG not the fastest but everything except Continuity Camera works out of the box. I use ethernet for Gaming on Windows and SteamOS.Thanks, I have Ventura Beta 11 installed. Running smoothly.
WiFi/Bluetooth kexts seem to cause a boot loop. It's late here so will tinker tomorrow.
Is the Fenvi T919 too slow to support Continuity Camera?
