zxc2689963
135
92
28
Brand: Lenovo
Model: Legion 5 6th Gen
CPU: AMD Ryzen 7 5800h
Ram: x2 8GB 3200mhz ddr4
Display: 15.6 1080p 165HZ
Updated October 5, 2023
Problems solved:
Unresolved issues:
Failure to wake from sleep
Solution
Panic from Monterey 12.6
Out of curiosity. Try the older patch set but with the new core count patches added so it'll actually boot. I'm wondering if an older patch that was removed can fix it for this scenario. I've already set the core count in the patches.
I'll try now, thanks
Should also note that the other cores are showing but listed as uninitialized because of cpus=1.
I can try to install Big Sur, since the installer also works with your patches without the cpus=1 signature, but the installer and the monterey system do not want to start, there is a new problem with these patches, see the photo.
But I also removed the cpus=1 argument
Interesting... So those patches allow the installer to boot without cpus=1 but not the installed system. I'll look over them and verify later on.
Please try these adjusted patches with cpus=1 removed.
Can I ask what's the SMBIOS that you use with the Monterey installer? Is it iMacPro1,1?
I tried it and started Monterey stuck. BigSur installation is ok
What about big sur once installed? Can you boot to the desktop without cpus=1?
Ok I think I know which patches are sorting it. Try again with this set. In theory Monterey should also work.
it works with big sur, but it also doesn’t want to work with monterey, photo when loading the monterey installer
That’s great. So the issue with Monterey there is GPU related. Try adding the boot arg -radvesa for the Monterey installer.
