Does your Ethernet connection works? mine dont I have both the latest kexts for ethernet but it's not working can you help? I also have Realtek PCIe 2.5GbE Family Controller and I'm running 0.8.0 Opencore
Goodnight!Does your Ethernet connection works? mine dont I have both the latest kexts for ethernet but it's not working can you help? I also have Realtek PCIe 2.5GbE Family Controller and I'm running 0.8.0 Opencore
OpenCore 0.7.8 EFI Update, February 8th, 2022
The EFI works with MacOS 12.3 Beta 1,2 & 3 on BIOS 4203 and includes Linux.
Changes made include,
NVMeFix was removed due to the stability issue with macOS Monterey 12.3 beta 1 & 2.
- Lilu
- AppleALC
- WhateverGreen
- VirtualSMC
- RestrictEvents
- AppleMCEReporterDisabler
- LucyRTL8125Ethernet
- SMCAMDProcessor
- SmallTreeIntel812576Ethernet
- New Universal AMD Patches Monterey 12.3 Compatible,
- 2.5Ghz Ethernet Auto Negotiation Fixed,
- Memory Mapping is now Being done via RestrictEvents,
- About This Mac now displays the correct AMD Processor info done via RestrictEvents,
- Plus other minor tweaks and changes to the config.
Note 1 - If your not using a RX 6800 or any other Navi/BigNavi GPU then remove agdpmod=ignore from the boot arguments.
Note 2 - If you are using a 6 or Less Core Ryzen then go into the Config,plist and under PlatformInfo->Generic Change the ProcessorType from 0 to 1537, This will list your CPU info correctly inside About This Mac.
Note 3 - The SmallTreeIntel82576.kext is not working in macOS Big Sur and Monterey.
Note 4 - BIOS SETTING CHANGE - Since Bios Revision 4010 Power On By PCIe can break shut down on some peoples builds so ensure the following setting is now set as disabled.
- Advanced -> APM Configuration -> Power On By PCIe -> Disabled
IMPORTANT PATCH INFO TO SET THE CORRECT CORE COUNT FOR YOUR CPU
Core Count patch needs to be modified to boot your system. Find the two algrey - Force cpuid_cores_per_package patches and alter the Replace value only.
Changing BA000000 0000/BA000000 0090* to BA <CoreCount> 0000 0000/BA <CoreCount> 0000 0090* substituting <CoreCount> with the hexadeciamal value matching your physical core count.
So for example a 6 Core 5600X would result in these replace values, BA 06 0000 0000/BA 06 0000 0090
CoreCount Hexadecimal 6 Core 06 8 Core 08 12 Core 0C 16 Core 10 32 Core 20
Or a 12 Core 5900X that I have it setup as standard would result in these replace values, BA 0C 0000 0000/BA 0C 0000 0090
EXAMPLE
Power Gadget App
AMD.Power.Gadget.app.zip
Big thanks to AudioGod, Shaneee & Ezual!
Hi thanks for your contribution, I based on your configuration for my case
I got everything to work except bluetooth, by default it recognizes the BCM_4350C2 model, so I want to ask you if any part of your configuration is configured? I already tried to correct it without success.
Motherboard: Asus x570 crosshair viii dark hero wifi
CPU: AMD Ryzen 9 5950x
Intel Wi-Fi 6 AX200 and Bluetooth
Unfortunately my AMD Radeon RX 6700 XT graphics card is not supported.
Sorry, I am confused are you using the Intel WiFi/ Bluetooth or the Broadcom?
The Intel does not have good support and stability. While the Broadcom for me has worked flawlessly.
12.4 works with OpenCore 0.8.0. Also 12.5 beta 1 works.What about macOS 12.4 Update ????
Sorry for the late reply. Is your mouse wireless? If you have a wireless mouse with a dongle and other wireless peripheral using 3.0 there seems to be an interference issue between the devices.Is anyone else having issues with USB 2.0 devices on USB 3.0 ports? If I use my mouse on an USB 3.0 port it stutters, same with my USB 2.0 DAC, it only happens with the ports on my motherboard but not on my 2.0 front panel ports. I also have an X570-E btw and I'm using the map by Ezaul.
Edit: Solved it by disabling the companion USB 3.0 port on USBToolBox and building a legacy kext as I noticed these EFI's usb map use AppleMergeNub instead of Apple...Properties. All lag is gone, did the same for my Apogee Duet (also USB 2.0), hope this helps anyone having this issue!
Hello, I recently received the Fenvi FV-HB1200, the wifi works without problems but the bluetooth does not, I tried what they indicate in the OpenCore documentation, among other configurations, but still without success. I have wifi and intel bluetooth disabled by bios, please do you know what else I can do?I swapped to the Broadcom. I would have really preferred the faster speeds of the Intel but stability was more desirable.
That is a strong possibility, but if you want/need a here and now solution; there is it.@alfie You benchmark results look right. To fix the CPU name just add the RestrictEvents.kext.
As for the I211-AT, patching back old networking kexts is a bit risky as Apple might break them with any update. And you have to re-do this after every update.
Hello, I was able to solve the problem with my Fenvi FV-HB1200, I investigated about the USB connectors on my motherboard and it turned out that USB_E56 is not compatible with standard USB, change to the correct one, now wifi and bluetooth worked without the need of any additional kext, change the Fenvi antennas for the one on my motherboard that fit perfectly with those on my motherboard, with which I have better coverage and the AirPods no longer have problemsThe Intel cards work for a while but mine crashed constantly and Bluetooth did not work at all.
The WiFi has Bluetooth are built in to the card, so by swapping to the card model that Apple uses it fixes both and there are no stability issues.
