you have to block the bluetooths path that you extract from your IO Reg and create a SSDT to do it with. I might actually have one from my old Z390 Master EFI somewhere that you could easily correct. Il have to have a hunt around and see if I can find it.
another thing you can do thinking about it is remove the USB map for the internal Bluetooth and this should have the same effect. I say should because things donāt always work out the way you think they willā¦lol
and awesome that airdrop now works on the internal Wlan, That must be a recent addition.
Stick with it and see how it goes.
Thanks for it!!!@6R23MeCe Disabling the integrated bluetooth is rather easy, just remove the USB port it is connected to from the USB mapping.
Confirmed working on Monterey with some tweaking.Does anyone know if the Aqantia 10GbE is working in Monterey ?
I was able to install Monterey 12.0.1 with @AudioGod's EFIs and I had to replace the intel smalltree kext with this one to get Ethernet working:
Intel I211-AT Alternative to SmallTree
If anyone wishes to progress it further please feel free, https://github.com/Shaneee/AppleIGB I contacted SmallTree and they have no plans to update their kext for Big Sur onwards, and no reply on sharing the source.forum.amd-osx.com
I wonder if small tree will get fix or if I should get a PCIe Ethernet card (and which one?)
Thanks! I will try one of those, as you said, it did not stick around for long.If it's anything like previous versions it'll come and go but won't stick around for long. I got fed up of WiFi speeds and bought this, https://amzn.to/3cBfm9L
Works OOB and works a treat.
Our EFI needs some AudioGod love.I always get a boot loop. Has anyone successfully installed 12.1 Monterey?
Post EFI here and let me have a look. AudioGod has been hit with lack of parts due to natural disaster and I aint just sitting down doing nothingI always get a boot loop. Has anyone successfully installed 12.1 Monterey?
I'm not so sure-- using this kext downright made my hackintosh unable to boot :/I was able to install Monterey 12.0.1 with @AudioGod's EFIs and I had to replace the intel smalltree kext with this one to get Ethernet working:
