    Votes: 12 75.0%
    Votes: 2 12.5%
    Votes: 2 12.5%
  • Total voters
    16
  • Poll closed .
Alright! Got it running! Will update my Success Stories for Aorus X570 Xtreme
I still don't know why bluetooth is not working.
If SmallTree is not working, then activate Aquantia 10GbE!
F33 still no dice. Boy do I regret not doing the beta sooner before lightning striked :(
I don't think it's your BIOS version that's causing the issue. BIOS setting, yes! Make sure both CSM and fTPM (if you installed Windows 11) are DISABLED in the BIOS. Setting to Optimized Defaults will enable CSM again and has bit me a couple times causing unnecessary headaches. Other than that make sure OC Ryzen patch for 12.0 is correct with the proper quirks enabled.
Did you add any other kexts on top of what AudioGod had? Did you fill "Arch" parameter correctly?
Reactions: svan71
I hope 4G Encoding is also disabled. The boot argument npci=0x2000 will cause boot to get stuck. Also IntelBluetoothInjector.kext also causes this, basing off from my Aorus X570 Xtreme
Reactions: svan71
How's the boot time for everyone? I just updated to 12.0.1 and it does boot fine.. after about 3-5 minute lol.
everything else is working fine except sidecar of course.
Reactions: operator777
has updated to Monterey , everything works fine except bluetooth, the problem is the bluetooth stops working from wake up, but if the hackintosh boots from power on , the bluetooth works good as on Big Sur. Monterey bugs or something else ?
Reactions: baronerosso
Message to everybody.
The other day I had a disaster at home and had a huge power surge that took out half the electronics in my house including my Computer, So many parts got burnt out that I am now totally out of action until further notice and will be unable to update the thread EFIs for a little while until I replace most the inners of my PC.
Sorry to be the bearer of bad news all but it’s to much money and to close to Christmas for me to sort out quickly so for now this is me signing out but I will return and continue trying to make things better for all as best as I can.
So sorry all but this one is out of my control.
Big Love
AG
Big Love
AG
Super sucks. I'm sorry to hear that has happened to you. Best of luck with electronics recovery during this horrible time for purchasing...
Reactions: svan71 and AudioGod
Update-- BrcmPatchRAM has 2.6.1 available today. If you want to get Bluetooth to work again in Monterey, download BlueToolFixup from 2.6.1 version, and add that kext into OC Config.plist along with IntelBluetoothFirmware.kext and you should be good to go. Do not include IntelBluetoothInjector.kext or you will not be able to boot.
Reactions: rmarmmzmxmr
Hi, I install fresh Monterey build, but I cant get ethernet working... I already try SmallTree all versions but none works
My hardware:
Ryzen 5900x
Aorus x570 Elite
RX 5700xt
All is working, except ethernet.....
This adapter works Aquantia 10GbE????
@Pabo I’m glad you find what happened to me funny mate. Deep Dude Deep.
I'm sorry, I'm sorry. I sent the wrong smiley. I would never allow myself to make fun of you for your misfortune ... You're helping us all here. On the contrary, I'm willing to send you some money to help. I apologize again...
Hi bro, what I must change on efi to work perfectly with my aorus elite? I use macpro 7.1
My hardware:
Ryzen 5900x
Aorus x570 Elite
RX 5700xt
The SmallTree kext is dead under Monterey I’m afraid. A alternative is being worked on but there’s nothing fully stable to replace it with as of yet.
You can try AppleGB.kext or one of its alias but the connection using that kext tends to drop out.
Post in thread 'Internet not working on I211-AT'
https://forum.amd-osx.com/index.php?threads/internet-not-working-on-i211-at.2189/post-14215
You just need to drop my USBMap.kext and make a new one for your Elite. Thats it really.
Hello AudioGod! I have similar build but i use only SSDT-EC.aml that i made at my own. I wonder if i should tweak my ACPI as yours. My hackintosh is running latest Big sur stable. Could you please take a look? I am not very familiar with the ACPI's, i did it following the Dortania's guide.
Also, i currently have MSI X570A-Pro and i want to switch it to other brand in order to get Monterey working. Do you recommend yours x570 Aorus? Or you would look for other one?
Yup all spot on for your board. 👍
Hi dude
I've updated to Monterey , everything works fine except bluetooth, the bluetooth stops working from wake up, but hackintosh can not be woken up by usb mouse click. have you met this problem ? much thanks.
