    Votes: 12 75.0%
    Votes: 2 12.5%
    Votes: 2 12.5%
  • Total voters
    16
  • Poll closed .
DarkSilentSC
Guess the lessons learned is do reset NVRAM religiously every time when you modify OC
MacOS also stores things in NVRAM, so a NVRAM reset might have some unintended side effects.
Usually it's better to work with delete keys.
isaiah12345
I keep getting crashing issues using this EFI. I tried the bone stock one from the first post and it did not work. I tried a fresh vanilla install of Big Sur and nothing. I also reset the NVRAM before booting. The sound also keeps cutting out unless I use alcid=28, which makes me have to manually swap to headphones instead of the speakers. I also don't have any overclock enabled on either the ram, manual, or PBO. I'm not sure what to try next. I have uploaded my EFI folder. Please help.
P.S. I am using Rev1.2 of the Aorus Master and my Mac drive is a WD Blue sata ssd. And I removed my serial number from the EFI for security purposes.
AntarcticPL
After days of testing, happy to post my working EFI. See signature for more details. Make sure to insert your serial, ... in the Platforminfo.
I have not enabled Wifi or Bluetooth yet, due to using Monterey and bluetooth implementation is buggy (I believe). But should be easy to add later.
Started from AudioGods EFI, but had to add driver and some kexts. Probably possible to make it a bit more clean, but this one at least works very stable!
6R23MeCe
you have to block the bluetooths path that you extract from your IO Reg and create a SSDT to do it with. I might actually have one from my old Z390 Master EFI somewhere that you could easily correct. Il have to have a hunt around and see if I can find it.
another thing you can do thinking about it is remove the USB map for the internal Bluetooth and this should have the same effect. I say should because things don’t always work out the way you think they will…lol
and awesome that airdrop now works on the internal Wlan, That must be a recent addition.
Stick with it and see how it goes.
@AudioGod May I know how exactly block out the built-in bluetooths/WLAN via SSDT? Or any doc I could refer to.
Background:
  • I managed to extract my SSDT (like SSDT.dsl) after learn a bit via https://dortania.github.io/Getting-Started-With-ACPI/ssdt-methods/ssdt-easy.html
  • and also learn some threads on blocking out the built-in bluetooths/WLAN via SSDT
  • My current understanding is that I need to remove the definition for the usb port responsible for the bluetooth in one SSDT with finding the correct port via IOReg.
  • From IOReg, my build-in bluetooth's path: IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/BXBR@1,2/IOPP/BYUP@0/IOPP/BYD8@8/IOPP/XHC0@0,3/XHC0@61000000/PRT5@61500000/BRCM20702 Hub@61500000/AppleUSB20InternalHub@61500000/AppleUSB20HubPort@61530000/Bluetooth USB Host Controller@61530000
  • however, still have no idea on how exactly makes it.
Thanks a lot!!!
@6R23MeCe Disabling the integrated bluetooth is rather easy, just remove the USB port it is connected to from the USB mapping.
6R23MeCe
Thanks for it!!!
So, supposed to?
1. remove the USB port that the build-in bluetooth uses
2. generate a new USBMap.kext
3. replace the old one with the new USBMap.kext
You can manually edit your current USBMap, it’s all in the Info.plist
svan71
Does anyone know if the Aqantia 10GbE is working in Monterey for the Aorus Extreme?
DarkSilentSC
Does anyone know if the Aqantia 10GbE is working in Monterey ?
Confirmed working on Monterey with some tweaking.
juliantoledo
I was able to install Monterey 12.0.1 with @AudioGod's EFIs and I had to replace the intel smalltree kext with this one to get Ethernet working:
I wonder if small tree will get fix or if I should get a PCIe Ethernet card (and which one?)
If it's anything like previous versions it'll come and go but won't stick around for long. I got fed up of WiFi speeds and bought this, https://amzn.to/3cBfm9L
Works OOB and works a treat.
juliantoledo
Thanks! I will try one of those, as you said, it did not stick around for long.
Edit: OrderedThe usb-c adapter on amazon and yes, it works OOB, I was able to remove the old network kext!
p2mmao
I am using MSI B550 Mortar WiFi+5800X, The original 11.6 system recognizes and enables two USB3.1 buses, but now 12.0.1 only recognizes and enables one USB3.1 bus, and Bluetooth is controlled by the lost USB3.1 bus, so Bluetooth WIFI can't be used, how to break it? I have already done USB customization in Windows 10, in the 11.6 , this USB customization completely normal, btw, I also lost my wifi and ethernet after upgrade
svan71
Happy Thanksgiving to all . I'm Thankful for Shaneee and AudioGod and all their work, here's hoping AG is back before Christmas. (y)(y)(y)
DarkSilentSC
Has anyone ran into issue of opencore suddenly booting all on its own? Tried XhciPortLimit=true, DisableRtcChecksum=true, applying FixShutdown-USB-SSDT.dsl, compiled with my own USB XHC0 path (_SB.PCI0.GP13.XHC0) but all these won't do anything uwu
Edit -- It seems the problem is getting worse-- I cannot find PMEE entry anywhere in my DSDT when I view it from MaciASL... Where to go from here? uwu
Edit2 -- Dorthania asks me to look for _PRWs in DSDT, but I get whole bunch of entries with GPPn entries... I'm totally lost on this one
xenearz
I always get a boot loop. Has anyone successfully installed 12.1 Monterey?
svan71
DarkSilentSC
Post EFI here and let me have a look. AudioGod has been hit with lack of parts due to natural disaster and I aint just sitting down doing nothing
DarkSilentSC
I'm not so sure-- using this kext downright made my hackintosh unable to boot :/
