@ufotom If you are using SMBIOS MacPro7,1 then try this EFI (Just add your details to the Config.lPlist) and if you’re not using a X570 Pro or Ultra then disable the USBMap.kext
If you’re using SMBIOS iMacPro1,1 then use the one on page one of this thread
also change
Kernel -> Quirks -> CustomSMBIOSGuid -> No
PlatformInfo -> UpdateSMBIOSMode -> Create
So you get SMBIOS injection across all other OS![]()
Thanks for the feedback.
As far as my hardware: Gigabyte Aorus Pro Wifi x570 rev 1.0 / 3900x / 128GB Ram / 5700XT / NVME1 - Macos 10.15.7 / NVME2 - Windows 10.
The only thing I've added to my config, that's different from yours, was the Intel Bluetooth driver you mentioned in the 1st post.
I was running OpenCore 0.6.4 and made the jump to 0.6.9 with your shared EFI since it's targeted towards my hardware platform ( It's a relief to have discovered it ). I've been wanting to update OpenCore so I could install MacOS BigSur and now I'm finally unblocked.
Changing EFI to: PlatformInfo -> UpdateSMBIOSMode -> Create
Results in hardware not initializing. Leaving it as a value of "", the hardware somehow initializes.
I need to start looking at what else is different between my legacy 0.6.4 and your 0.6.9. Sometimes if it appears too easy... it may not be.. lol
