I have tried running the seperate waves apps, but they crash just like Avenger:It should work if they are AU, try changing the string with Ableton directory inside Ableton pckg; instead of logic one.
Problem with Waves on AMD hack is that waves central doesn't recognize main drive and you get stuck to "please restart or contact support", you can still install V10 tho
command to try: MKL_DEBUG_CPU_TYPE=5 /Applications/Waves/Applications\ V11/CODEX.app/Contents/MacOS/CODEX
_intel_fast_memset errors all over the place
@Shaneee Theoretically, is this something that could be patched in OpenCore or via a kext? Like the Adobe patches, is this not something that can be fixed on a higher level?
