** Serial Port Debugging -- Quick Status Update **
The StarTech PEX2S953 dual-port RS232 PCIe card arrived today. Installation was plug-and-pay. The card is natively supported in macOS (Monterey). Because I'm running FrankenMon, the PCIe card works properly. We can see this in IOReg screenshot:
However, so far I have not been able to get debug output through the serial port.
- I'm using two Hackintoshes for this experiment
- System 1: FrankenMon with AMD Ryzen 7 7700X and StarTech RS232 PCIe card
- System 2: Intel Z690 with Ventura and USB-to-Serial port adapter (with Null modem wiring)
- CoolTerm is running on System 2 with proper Baud, Parity, and Stop Bits
- A test using CoolTerm on both systems was successful
- Anything typed into CoolTerm on System 1 appears on System 2, and vice-versa
- This shows that null-modem cable connection is correct
To enable OpenCore and macOS to perform serial logging through the PCIe serial port, these changes were made...
Misc --> Serial: I tried with
Override turn off and on. Not sure if RegisterBase is correct, hence disabling
Override is better because OpenCore is supposed to set these parameters by itself.
Misc --> Debug: The flag to enable serial port logging is enabled (this is required).
NVRAM --> boot-args: This can be tricky (along with serial override parameters). I've tried various combinations.
My plan is to re-read the technical discussion on GitHub and look for any additional documentation in the source code. I can contact joevt if all else fails.
