I have G.Skill Neo, which is AMD EXPO certified.Who has amd expo certified ram?
Time from Power-On to Asus-Logo | |
Before disabling Memory Retraining in BIOS | 38 seconds |
After disabling Memory Retraining in BIOS | 20 seconds |
My mistake -- I meant "enabled". Previous post has been corrected.If set to enabled, it should reduce even more, but always test the stability of the system
Could someone try Continuity Camera with the new commit of FeatureUnlock: https://github.com/acidanthera/FeatureUnlock/commit/0e8d87f1ab3890e4805f4852428e43cf639a6c0?
The AMD patches spoof the CPU to Intel 1st generation, Penryn, so this might fix the black screen.
Check the dmesg for the line that says patching Continuity Camera, if it's not there, we'll need to modify the code for AMD.
Yes it works!Could someone try Continuity Camera with the new commit of FeatureUnlock: https://github.com/acidanthera/FeatureUnlock/commit/0e8d87f1ab3890e4805f4852428e43cf639a6c0?
Time to upgrade your AM5 system....
when @CaseySJ and @Shaneee and @ExtremeXT get Continuity Camera working on Ryzen, I will upgrade my AM5 system. but until then, I will stick with Monterey.
Ill repost in the Ventura installation field:It looks as if your EFI folder has been copied-and-pasted from a different system. Please have a look at this post for guidance on creating a new EFI folder:
** Preliminary Build Guide for Asus X670E Gene and Other AM5 Boards ** Also refer to this Outline of the Steps Supports Big Sur, Monterey and Ventura 14 April 2023: Added OpenCore 0.9.1 EFI Folder See post #5 below for details and EFI folder NOTE: If you choose to use the files and...forum.amd-osx.com
macOS Monterey and Ventura do not support "trim" on Samsung 970 Pro, so boot times can be high (30 seconds for some, 2 minutes or more for others). WD, Silicon Power, Kingston, Crucial, and other brands work well.
Also feel free to start a new thread under Installation -> Ventura (assuming Ventura is the target version) and we can help you there.
Yes it worksCould someone try Continuity Camera
I'm using the same kit. we got off to a rocky start, but it has been rock solid since I finished the build.I have G.Skill Neo, which is AMD EXPO certified.
G.SKILL Trident Z5 Neo RGB Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3238F16GX2-TZ5NR - Newegg.com
Buy G.SKILL Trident Z5 Neo RGB Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3238F16GX2-TZ5NR with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.com
do you use Shaneee fix pat patch or Algrey one in your kernel patches section?Guys. I got lack of performance of gaming on the new am5 system
Previous build using 11700k and the same rx6600xt , I got up to 100fps easily but on 7950x , sadly it couldn't pass over 40fps , same setting
Any ideas for this ?
I think you think bad
