I've been away so maybe this is discussed already.Yes we want
The rumor mill is really churning with talk of Compute Modules. MaxTech posted this video yesterday...
It's March 1 today (in this part of the world), so if a March event is coming it will be here soon...
as their MacPros never really had a significant upgrade path CPU wise.
Apple does not care about Hackintosh. Never has, never will.what bugs me, is that they seem to be killing off hackintosh by refusing to allow discrete GPUs from AMD/NVidia. I have PowerColor 7900XTX collecting in a box collecting dust b/c I can't use it in my hackintosh builds. annoying.
Otherwise they could destroy it in one easy stroke, simply by refusing iCloud usage on non-recognized serial numbers. All those numbers we use, thatselfsolve.apple.comcheckcoverage.apple.com does not recognise — poof and Hackintosh is dead. Computers today are so cloud-service dependent/connected that without iServices they would not be worth it to vast majority of people.
One day later, how is the new build?My build am5 is ready
I have 4 Hackintosh builds, so yeah, I feel you— I would love to be able to use better hardware in them. Especially a more modern WiFi/Bt stack.but without more modern hardware support we are relegated to tinkering with old hardware just for the fun of it.. which is cute too.. but disappointing.
these days, I like to have the latest and greatest.
silly me.
you have to read a bit deeper in this threadHello,
Hoping for some help,
I have just finish building this:
Ryzen 9 7950 X3D-32GB DDR 5 16x2-2 NVME SSDS: Samsung 970 Pro - MacOS, WD Black 1TB Windows 11-1TB WD Black Storage HDD
Asus ROG B650E - F Gaming WIFI-FenviT919 - Wifi/BT- Asus TUF RX 6800 XT 16GB- Deepcool C510 Mesh Digital Case -Segotop 850W PSU
The problem is I cannot boot. Im currently using OC 0.8.9
When I boot to the install I either get a denied symbol with the apple support link or I tried turning the gpu off in my config as well and then it just reboots.
Im not really sure what to make of what I see in the debug logs and im hoping I can get any suggestions as to try.
My initial concern was something incorrect with the kernel patches, but I believe they are correct, I even added the additional section so that I can install the new beta.
Thank you and if this isn't the right place for this post please remove.
It looks as if your EFI folder has been copied-and-pasted from a different system. Please have a look at this post for guidance on creating a new EFI folder:Hello,
In early versions of Ventura we needed a SSDT to modify sub-vendor device ID for i225-V. In current versions of Ventura, the SSDT is no longer needed.
There doesn't seem to be any harm in keeping the SSDT.will leaving the SSDT in place break anything in newer versions of Ventura?
I'm a creature of habit and have gotten rusty with my hackintoshing since I have 2 very stable AMD hackintoshes that I'm no longer tinkering with.
Ah, I missed that post...@CaseySJ
check here
Feb 5, 2023
(about no need of any SSDT for i225)
also in old Ventura or Monterey my motherboard doesn't need of it
