is it different from what I did in the first post?@edonkey
another approach is to add the FakeID under the Device Properties instead of using the SSDT like in this example:
have you been able to solve it? I'm in the same situationAlright I'll report back if I ever get something to work. Thank you guys for the support
Could you help me with this? I checked all the fakeid from AMD 8000, all to no avail. Now I have already checked half of the AMD 7000, but so far it has not worked out. I would be very grateful.no-gfx-spoof is needed in the device property sometimes for a device ID to work.
Unfortunately, I also tried, it didn't work out. I attach screenshots of my settings. Hands are already droppingThe device ID3D680000
should work. In your device property in the config for the GPU also add no-gfx-spoof with the value01000000
Could you look at my EFI? After all the operations, I get a black screen. The computer is working at the same time, it does not turn off.You don't need to use -lilubetaall boot arg. Monterey is not a beta release, it isn't required for Ventura either.
You may need to use the following boot arg
To force the spoofed PID to be used in AMDRadeonVADriver.
- -radcodec
ASUS m5a97 r2.0 with last bios update.@Alexflyme which make and model of motherboard are you using with the FX-4300 4-core CPU?
Thank you, I will definitely try on Monday. Unfortunately, the computer is at work now, there is no possibility. I will definitely let you know about the result on Monday.Never mind.
Try this EFI see if it makes any difference.
Found a problem why I didn't have an image after loading EFI. A slot was reassigned to SSDT-BRG0, I inserted the video card into another one and the image appeared. But the problem remained, still display 3mb. Your EFI also tried, the black screen does not reach the EFI bootloader (as soon as I choose to boot from a USB flash drive, the screen is black immediately and even EFI does not appear.)Never mind.
Could there be a problem in SPOOF? I inserted my video card into a Windows computer. The path shows this - ACPI(SB)#ACPI(PCI0)#ACPI(GPP8)#ACPI(X161)Never mind.
