Problems getting a R7 240 to work
Cyberdevs
it appears to be the same except for the no-gfx-spoof entry which i don't know what that is, you can try different ids to see which one will work on your card.
The zipped file below contains the device ID's for most if not all of the AMD GPU's natively supported in macOS.
See if you can find one that is similar to your cards (0x10026611) device id in this file, hopefully one will work.
The AMD 8000 Controller looks the most promising.
  • AMD GPU Device IDs.zip
edonkey
Alright I'll report back if I ever get something to work. Thank you guys for the support (y)
no-gfx-spoof is needed in the device property sometimes for a device ID to work.
Alexflyme
Faced the same problem. Has no one decided? The video card is exactly the same. HP R 7 240. I am ready to accept any help.
Alexflyme
Could you help me with this? I checked all the fakeid from AMD 8000, all to no avail. Now I have already checked half of the AMD 7000, but so far it has not worked out. I would be very grateful.
The device ID 3D680000 should work. In your device property in the config for the GPU also add no-gfx-spoof with the value 01000000.
Alexflyme
Unfortunately, I also tried, it didn't work out. I attach screenshots of my settings. Hands are already dropping :(
You don't need to use -lilubetaall boot arg. Monterey is not a beta release, it isn't required for Ventura either.
You may need to use the following boot arg
  • -radcodec
To force the spoofed PID to be used in AMDRadeonVADriver.
Alexflyme
  • -radcodec
Could you look at my EFI? After all the operations, I get a black screen. The computer is working at the same time, it does not turn off.
@Alexflyme which make and model of motherboard are you using with the FX-4300 4-core CPU?
Never mind.
Try this EFI see if it makes any difference.
Alexflyme
Never mind.
Thank you, I will definitely try on Monday. Unfortunately, the computer is at work now, there is no possibility. I will definitely let you know about the result on Monday.
Alexflyme
Never mind.
Found a problem why I didn't have an image after loading EFI. A slot was reassigned to SSDT-BRG0, I inserted the video card into another one and the image appeared. But the problem remained, still display 3mb. Your EFI also tried, the black screen does not reach the EFI bootloader (as soon as I choose to boot from a USB flash drive, the screen is black immediately and even EFI does not appear.)
Alexflyme
Never mind.
Could there be a problem in SPOOF? I inserted my video card into a Windows computer. The path shows this - ACPI(SB)#ACPI(PCI0)#ACPI(GPP8)#ACPI(X161)
Yes, the spoof won’t work if the ACPI path is not correct.
