Problems getting a R7 240 to work
edonkey
I'm back again with another and last problem (I hope lmao).
This is my GPU
I've tried to follow this forum thread and also this one but with no success.
Using hackintool, I see that the GPU device id isn't changed(?)
My config.plist looks like this
and the ssdt I've used (the path of the graphics card is /PCI0@0/AppleACPIPCI/GPP2@1,3/IOPP/PT02@0,2/IOPP/PT24@4/IOPP/GFX0@0)
DefinitionBlock ("", "SSDT", 2, "DRTNIA", "AMDGPU", 0x00001000)
    External (_SB_.PCI0.GPP2.PT02.PT24, DeviceObj)
    Scope (\_SB_.PCI0.GPP2.PT02.PT24)
        Device (GFX0)
            Name (_ADR, Zero)  // _ADR: Address
In order for anyone to be able to help, you need to provide the following:
  1. Post a copy of the SSDT you created, both disassembled and .aml versions.
  2. Post a copy of the Hackintool > PCIe > Export - pcidevices.plist
  3. Post a copy of your IOReg, use the version attached below.
How to Make a Copy of IOReg (Note 1)
1. IORegistryExplorer/File/Save a Copy As…. (no extension required)
2. Open file to verify (Note 2)
3. Attach to post as a zipped/compressed folder
Installation
1, Open Downloads/IORegistryExplorer-SLRID_v10.6.3
2. Drag IORegistryExplorer to Applications
Notes
1. An IOReg.txt is not useful. It is not a "Copy of IOReg." Do not attach .txt files.
2. IOReg must open the file. If TextEdit opens, See Note 1.
  • IORegistryExplorer-SLRID_v10.6.3.zip
edonkey
Hey sorry for the waiting, I wasn't available, here you go.
  • all.zip
I have created an SSDT, which I have attached below. This SSDT-GPU-SPOOF-R7-250X.aml should work with your system to spoof the R7 240 discrete GPU.
Try it in place of the SSDT you are currently using. See if it work.
  • SSDT-GPU-SPOOF-R7-250X.aml.zip
edonkey
Just tried and unfortunately it still does the same thing
What other ‘fixes’ have you tried?
Did you remove the failed ‘fixes’ when it became apparent they didn’t work?
edonkey
This was the ssdt I've used
  • gpu_spoof.zip
Are you using the config.plist DeviceProperties entry to spoof the device ID AND the SSDT-GPU-SPOOF.aml?
The two should not be used together, use one or the other not both.
Your IOReg shows two GFX entries. GFX0 and GFX1.
  • GFX0 shows a Radeon R7 250X attached in Slot-1
  • GFX1 shows a Nvidia GTX 1660 attached in Slot-2
Are you using an SSDT-Disable-dGPU.aml for the Nvidia GTX 1660? Is it set correctly to disable the GPU in slot-2?
The ACPI address for the GTX 1660 is (/_SB/PCI0/GPP8/GFX1), its that the address your current SSDT-GPU-DISABLE.aml uses?
Try this SSDT-GPU-SPOOF.aml the ACPI address has been extended to include the GFX0 part of the address, which was missing from both mine and your previous SSDT's. See if that works any better. Remember to remove the DeviceProperties for the GPU spoof when adding this SSDT.
I have also attached an SSDT-GPU-DISABLE.aml, that should disable your Nvidia GPU when running macOS.
  • SSDT-GPU-SPOOF.aml.zip
  • SSDT-GPU-DISABLE.aml.zip
edonkey
Yes I've made an entry in DeviceProperties when I've tried the second solution as you can see in the first post, the 1660 was disabled and that's not a problem fortunately.
I've just tried the new aml you sent and right now in system info it shows the default gpu name as before (yes I've removed the property in config.plist).
I'll also send the ssdt for disabling the gpu that I was using.
  • gpu_disable.zip
Maybe you need to talk to @Cyberdevs he seems to be fairly good with SSDT patching/spoofing etc.
Cyberdevs
@edonkey
Remove the device properties entry for the GPU and try this SSDT:
P.S.
What is the model of your GPU exactly? I mean which brand?
  • SSDT-GPU-SPOOF 240.zip
edonkey
Just tried and nothing changed, I have an oem card from an hp computer I had laying around
Cyberdevs
It's a little bit tricky since I don't know the exact device ID for your GPU is, I just can't find the best matching fakeID for it so we have to try different options.
I think this is a copy of the GPU-Z information for the dGPU
Screenshot 2022-03-14 at 17.03.18.png Ven/Dev ID 0x10026611
Cyberdevs
ok try this one:
Also add radpg=15 (and -radcodec might not be necessary) under nvram section. Do a nvram reset before booting into macOS by pressing the space bar in OpenCore GUI if the nvram reset isn't available by default.
edonkey
Nope still the same and reset nvram too, also I always had radpg=15
Cyberdevs
@edonkey
another approach is to add the FakeID under the Device Properties instead of using the SSDT like in this example:
