Hi peeps,
Having a few issues with the new build. I used OC Simplify to put together the EFI, due to struggling with the Dortania guides. I have a feeling that some kexts are conflicting or incorrect, or SSDT configuration shenanigans.
- Machine not shutting down/booting properly
I'll sometimes need to reboot the machine a number of times to get to the login screen and a proper shut down requires holding the power button until the machine turns off.
- Bluetooth not working properly
I have a Broadcom card with BCM_4350C2 chipset, I had Bluetooth and Handoff working on one boot but it's disabled on subsequent boots.
- Ethernet not working
Realtek8111.kext not working, motherboard chip is a Reaktek 8118 chip. I've tried a few older versions of this kext but haven't had any luck activating the port.
If this is unable to be used is a USB to Ethernet adapter a viable option?
- Best way to map USB ports?
I think the limit for MacOS is 15 ports so I should be fine to enable them using USBTool however I have something like 30 ports appear. I have a feeling this means that USB3 ports are appearing as 2 ports due to being USB 2 & 3.
- Motherboard has 1 x USB C, 4 x USB 3 & 2 x USB 2 ports
- FW card (Sonnet FW800 PCI card) has 2x USB 3 ports
- 2 x USB 3 & 2 x USB 2 on the PC case
Just to note - Anytime I've added or removed kexts I've used ProperTree to rebuild the config file so hopefully there's no redundant entries in there. Have also reset NVRAM when applying new kexts if they don't appear to work after rebooting the system.
Snapshot of kext directory and config.plist file attached.
Thanks in advance for your assistance.
