if i'm not wrong, SetApfsTrimTimeout=0 is to disable the trim feature.Check to: SetApfsTrimTimeout=0
isn't that bad for SSD?
https://github.com/acidanthera/OpenCorePkg/pull/357Thanks for the reply but the problem is still stuck in the logo and language selectionCheck to: AvoidRuntimeDefrag = False, AdviseFeatures = True
Try to disable the WiFi driver if you have one.Thanks for the reply but the problem is still stuck in the logo and language selection
hello how to disable bcm943602csTry to disable the WiFi driver if you have one.
You need to check your config.plist in your EFI folder and see if you have a WiFi driver enabled, typically it should be Airportitlwm or Airportbrcm. Simply edit your config file using either Propertree or Plist Editor. Look for it under Kernel > Add > Item and set Enable to NO.hello how to disable bcm943602cs
problem solved thanksYou need to check your config.plist in your EFI folder and see if you have a WiFi driver enabled, typically it should be Airportitlwm or Airportbrcm. Simply edit your config file using either Propertree or Plist Editor. Look for it under Kernel > Add > Item and set Enable to NO.
Hello, my problem has been solved, format the hard disk and install the official version of mac12.4, upgrade the test version of mac13 online, and the installation is successful.Do you have time to look at my configuration for me? thanks
Is it the online upgrade of 13 after installing the 12.4 version on the grid? I succeeded after this operation. I cannot install the Kepler graphics card driver under 12.4, otherwise it will restart infinitely. After installing the 12.4 version directly, other drivers are not installed, and then try to upgrade the 13 version online.After installation, i stuck here (I don't even get to language selection / create account). 1-2 min system freeze and reboot.
Hi p2mmao,I managed to upgrade from 12.4 to 13beta with an MSI B550M Mortar Wi-Fi motherboard, EFI see attachmentView attachment 6139
Yes, for certain.I'm using an x570 board, 3700x and an RX 6800 XT. Are my present boot args (npci=0x2000 agdpmod=pikera alcid=29) still needed for Ventura beta?
