AMD Radeon RX590 problem with Monterey - No GPU acceleration
spykor
39
hi! I am looking for help for my Hackintosh GPU problem. I have been hackintoshing for some years now (since OSX Maverick). Usually I managed to solve most problems even by hacking GPU drivers. But my attempt to upgrade to Monterey has failed. I have a system based on: mobo GA-990XA-UD3 (UEFI), CPU FX-6300, Mem 8GB, GPU NITRO+ AMD Radeon RX590 8GB, 1TB SSD with Monterey and 120GB SSD with Big Sur. Big Sur works just fine. Monterey works only without GPU acceleration (NVRAM > boot-args = -amd_no_dgpu_accel). If I enable GPU acceleration in OpenCore (remove the -amd_no_dgpu_accel argument) then after the accelerated Apple logo during boot the screen goes black. Any ideas?
Post a copy of your EFI folder, so we can see exactly what you are using with your old FX system. Otherwise we will be at a complete loss as to what could be the cause of the black screen.
You might want to have a look at this old FX success story, it may give you some ideas on what might help.
Here is the EFI I am using
My Big Sur Installation also works fine. It's Monterey that doesn't work with GPU acceleration!
You have duplicate SSDT-EC & SSDT-USBX entries in your OC setup.
You should either use the two separate SSDT's or the combined SSDT-EC-USBX-Desktop.aml table not all three at the same time.
You have the ACPI patch present and enabled for SSDT-XOSI.aml table, but the SSDT is not present in your OC Setup. Either add the SSDT or remove/ disable the patch. They do nothing without both being present and enabled.
BrcmBluetoothInjector.kext isn't supported in macOS Monterey or newer. It was replaced by BlueToolFixup.kext for Monterey or newer.
If you need this kext to boot Big Sur or older, then simply set the MaxKernel entry to prevent it being used in Monterey or newer, i.e. MaxKernel=20.99.99
BlueToolFixup.kext should likewise be prevented from being loaded in anything older than Monterey, i.e. MinKernel=21.0.0.
I don't see anything in your OC Setup that would prevent the RX 590 booting macOS with full graphics acceleration. You definitely don't require those DeviceProperites that you added to the other config.plist.
Try this revised EFI, see how you get on with booting Monterey.
Thank you very much for your advise and efforts. I tried your modified EFI (and config.plist) and the result is still the same. Black recurring screen after the Apple logo, when set for GPU acceleration. I tried the latest version of OpenCore (OC 1.07) with the the corresponding config.plst but it results in Kernel panic a few second after the Apple logo and the black screen. I attach the relevant EFI
This is the latest EFI based on OC 0.98 which seems to be normal, but it only works without GPU acceleration
I have fixed all the possible problems for EFI/OC setup. I attach the latest EFI, but the problem remains. No graphics acceleration. When booting process reaches the point to open the login screen the system goes to black screen and the display goes between black screen and some display info messages and then round and round. I reinstalled Monterey to a new disk (SSD) and it went smooth all during installation and setup (graphics acceleration and all) until I rebooted the system to work with the new system after I transfered the USB installer EFI (which had worked fine the 1st time during installation) top the new disk and booted from it. Black screen etc. It seems the system fails graphics acceleration when it reaches login screen
Back again! Stoll struggling with Monterey on my system. Problem persists. Anybody solved it? The problem manifests itself at the moment the system reaches Login Screen. I entered relevant information in ChatGPT but have not been able to pinpoint what causes the problem. Anybody else managed to make Monterey work on a Gigabyte 990XA-UD3 with AMD FX-6300 CPU and AMD Raden RX590 GPU?
The RX590 should work without issue on Monterey with OpenCore. Please test this EFI, if it still fails get your PCI Root for the GPU and add a property for built-in. Only Powercolour and XFX cards create issues but your Sapphire card should work. Also the RX 590 GME needs to be flashed with the 580 VBIOS.
If you need to get PCI Root via Windows refer to this guide, https://dortania.github.io/Getting-...l/spoof.html#finding-the-acpi-path-of-the-gpu
Thanks a lot for your response. I checked you attached EFI and the rtesult is still the same. Now, some info about my GPU card nad couple of questions. My graphics card is Sapphire NITRO+ Radeon RX 590 Special Edition 8GB DDR5. Does it mean anything about what it needs to be functional in Monterey? Also, What it means "if it still fails get your PCI Root for the GPU and add a property for built-in" ? How can I add a property for built-in? Thanks! Have a nice day!
When you get the device path via the link I shared you can add it to the config like so,
<key>DeviceProperties</key>
    <dict>
        <key>Add</key>
        <dict>
            <key>PciRoot(0x0)/Pci(0x7,0x0)/Pci(0x0,0x0)</key>
            <dict>
                <key>built-in</key>
                <integer>1</integer>
            </dict>
    </dict>
What you'll change is PciRoot(0x0)/Pci(0x7,0x0)/Pci(0x0,0x0)
    <dict>
        <key>Add</key>
        <dict>
            <dict>
                <key>built-in</key>
            </dict>
    </dict>
OK, thanks! I'll try it
