AMD Athlon II X2 MacOS yosemite
Sorry, but with those specs you are probably wasting your time.
The dual core CPU and limited RAM mean you might possibly get it to run Snow Leopard, or Lion with a patched kernel or distro, but anything newer might be a step too far.
The AMD vanilla method definitely won't work on your system.
Sorry to hear that, not sure what else to suggest regarding your old system. As the patched kernel was the best chance for your system to boot in to the macOS Yosemite installer.
This kernel indeeds go way further than any other kernels! when I put the kernel into /S/L/K inside Yosemite Zone Installer (I can't find any other full installer that cam be kernel-swapped) and it get past still waiting for root device, launchd spam, but stuck at the end with invalid opcode, and if I try clover I don't have any knowledge on clover since I usually do OpenCore on my Intel machine, I need a little assistance for this since I have tried for a couple months now
Or maybe the limitation is the nForce SATA controller 430, opencore won't even get past ocb loadimage failed unsupported
The drivers are added properly, snapshot properly, but it won't get past that scrn
Yosemite Zone if memory serves me right, contains a number of different Kernels, which can be called to be used by entering a specific boot argument, i.e. ‘AMD’ so the AMD Kernel is selected by the Distro. Have you tried using the AMD Kernel contained in the Distro?
It may also contain a number of legacy kexts that may work with your setup, but I can’t recall how these would need to be added to the configuration.
There's plenty of AMDs in there, the distro one most of them will stuck at still waiting for root device, AMD32 panic at iousbehci, for the shaneee kernel that he gave, it did go way further and stop at invalid opcode
Which boot arguments are you using to help the installer boot?
I can give you the picture of the error itself where I got stuck so you can have more information for further help
I moved to 10.10.1 zone since 10.10.5 won't boot, is there any kernel that gave me most chances of entering the installer? Only AMD32 kernel inside the thingy work and panic at corecrypto kext, the rest in the installer won't get past waiting for root device
You would need to look in the ‘Zone’ setup/USB you downloaded to see which AMD kernels were available.
With regards the ‘Still waiting for Root device’ error this is caused by the installer not activating the USB port you are using for the Yosemite installation device. You need to move the USB to a different port, and the installation should continue, if the port you moved the USB pen drive into is active/enabled. You may need to test a few USB ports before you find one that works with the installer.
Literally trying to do lots of combination of boot args that fixes USB stuff, and I think I gave up on os x 10.10.1 zone since the USB stack is old, 10.11 zone didn't exist but the USB stack is new and working on this legacy rig, I might find a kernel then find an Intel image of El Capitan and put Kexts I needed there and the kernel itself, however in the 10.11 kernel development section on InsanelyMac, most of the kernel links are dead, is there any kernel for 10.11 AMD since I'ma make my own full installer
