stuck on [EB|#LOG:EXITBS:START]
funkyman
9
AMD FX6300
Hi All!
I wan to install Monterey 12.4 ,but booting stuck on [EB|#LOG:EXITBS:START]
What i've tried: old and new kernel patches for OC,installing from usb stick and from hdd.
mobo: ASUS M5A78 LE
CPU: AMD FX-6300
GPU: SAPPHIRE RADEON R9 270X
24GB RAM
Please check my EFI folder.Thanks for help.
UPDATE: I've installed Monterey succesfully and reached the desktop,installed OC 1.05 on system EFI,but after restart my graphics is flashing and I can't reach the desktop again.I've tried CleanNVRAM but it did not help.
Have you set your macOS UEFI drive or the OpenCore entry in your bios as the default/first boot option?
What do you mean when you say, your graphics is flashing?
Which display connector, cable or adapter are you using to connect your Hack to the display?
Yes,everything set correctly in bios.I had to reinstall the whole system again.There was a problem with OC debug version,so I've used release version.After booting to desktop there was no internet lan connection.i needed to change realtek 8111 kext for older version 2.4.2 .
R9 270X is connected through HDMI to monitor.Another problem is with external usb soundcard PreSonus Audiobox iOne.it's not recognized by system.Usb should be mapped,but i don't know how to do it.
Mapping the USB ports on your old AM3+ motherboard will be difficult, as it will be using older USB controllers.
If I recall correctly it will use an AMD and an ASMedia USB controller. You may find that only the USB3 ports served by the ASMedia controller will work with any normal function in macOS. That was one of the issues I faced when using my old (retired) AM3+ systems. I ended up disabling the AMD USB 2.0/1.1 ports and adding a Fresco Logic (FL1100 controller) PCIe USB card to provide a sufficient number of USB ports.
Logically your external audio card/device needs to be connected to one of the 4 x ASMedia USB3 ports for it to have any chance of it working.
Hi, I'm stuck on
[EB|#LOG:EXITBS:START] as well. How did you fix this?​
@maksymo questions:
  1. On which system are you trying to install macOS?
    1. Provide full details of your system.
  2. Which version of macOS are you trying to install?
    1. Provide a copy of your OpenCore EFI folder, with the serial number redacted/deleted from your config.plist.
Hi, @Edhawk , thank you so much for your response.
So the system info from msinfo32 is the following:
"OS Name Microsoft Windows 11 Pro
Version 10.0.26200 Build 26200
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-730STC9
System Manufacturer To Be Filled By O.E.M.
System Model A520M-HDV
System Type x64-based PC
System SKU To Be Filled By O.E.M.
Processor AMD Ryzen 3 3200G with Radeon Vega Graphics, 3600 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends International, LLC. P3.50, 05/09/2024
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASRock
BaseBoard Product A520M-HDV
BaseBoard Version
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Locale United States
Hardware Abstraction Layer Version = "10.0.26100.1"
User Name DESKTOP-730STC9\USUARIO
Time Zone Romance Standard Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 13.9 GB
Available Physical Memory 9.68 GB
Total Virtual Memory 14.8 GB
Available Virtual Memory 10.4 GB
Page File Space 896 MB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
App Control for Business policy Enforced
App Control for Business user mode policy Off
Automatic Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes"
And here's the info from Opcore-simplify:
"1. CPU:
- AMD Ryzen 3 3200G: Up to macOS Tahoe 26
2. GPU:
- AMD Radeon(TM) Vega 8 Graphics: macOS Catalina 10.15 to macOS Tahoe 26
- Connected Monitor: LG FULL HD (HDMI)
3. Sound:
- iStore Audio: Up to macOS Tahoe 26
- Audio Endpoints: Micrófono, Altavoces
- High Definition Audio Device: Up to macOS Tahoe 26
- AMD High Definition Audio Device: Up to macOS Tahoe 26
- Audio Endpoint: 2 - LG FULL HD
4. Network:
- Realtek 8811CU Wireless LAN 802.11ac USB NIC: Up to macOS Tahoe 26
- Realtek PCIe GbE Family Controller: Up to macOS Tahoe 26
5. Storage Controllers:
- 500 Series Chipset SATA Controller: Up to macOS Tahoe 26
- Patriot P300 NVMe SSD (DRAM-less): Up to macOS Tahoe 26
6. Bluetooth:
- Generic Bluetooth Radio: Up to macOS Tahoe 26"
I'm trying to install Monterey because it's the only macOS I was able to run, in VMware only though. Also I tried Sequoia, Sonoma, Ventura. The methods were different though. I've tried this and that for both VMware and USB stick installation. Don't remember exactly which and where but tried some options to see if the issue is the image.
When I do the "1. Select Hardware Report", it asks me to "Please drag and drop ACPI Tables folder here:". So I provide the "C:\Users\USUARIO\Desktop\OpCore-Simplify-main\SysReport\ACPI" and push Enter, but it asks one more time again immediately. And after providing same folder again, it goes directly to the main menu without any notice.
For the third time it's asking me to do that when I do the "6. Build OpenCore EFI".
Maybe that's why my list of ACPI is empty when I open the "C:\Users\USUARIO\Desktop\EFI\OC\config.plist" file in OCAuxiliary tools...
By the way on "1. Select Hardware Report" it would also keep asking me twice if I don't provide it with any path just keep pushing Enter.
Attaching the EFI folder in a zip-file. I've changed the alpha-numeric string that goes right below the
<key>SystemSerialNumber</key> preserving the alpha-numeric quantity and order but different letters and numbers.
Thank you for reading this!
You are missing SSDT-CPUR.aml from your /EFI/OC/ACPI folder. This is an essential SSDT for an AMD A520 motherboard. System won't boot without this SSDT.
Also you should have SSDT-EC-USBX-AMD.aml in your ACPI folder, as this is a basic/essential SSDT for all AMD Hacks.
When using NootedRed.kext you should not be using any DeviceProperties in your config.plist, this is a common issue for AMD IGPU setups. They should both be removed from the config.plist.
You may need to disable NootedRed.kext in the config.plist during the macOS installation, as having it enabled can often cause issues. Only enable the kext once you have reached the macOS desktop.
The Realtek WiFi/BT card in your system won't work in macOS, any version. So you shouldn't have USBToolFixup.kext in your OC setup.
You shouldn't have UTBDefault.kext and UTBMap.kext in the setup at the same time. If you have created a custom UTBMap.kext then remove UTBDefault.kext.
Misc > Security > SecureBootModel should be set to 'Disabled' not 'Default' in your config.plist for your system to boot macOS.
You don't need these Intel IGPU boot arguments in your config.plist - igfxonln=1 igfxvesa, remove them both.
Make the changes recommended above and see if that helps.
Hi @Edhawk,
Thanks to you I was able to advance this far(attaching a photo in a zip-archive).
I even tried to use Sequoia (which I also downloaded using macrecovery from the Open-Core-1.0.5/Utilities/ folder using the "py macrecovery.py -b Mac-937A206F2EE63C01 -m 00000000000000000 download" command).
But Sequoia gave me same output.
Steps I made:
added SSDT-CPUR.aml and SSDT-EC-USBX-AMD.aml to /EFI/OC/ACPI folder and to the config.plist (using OCAuxiliary tools)
disabled NootedRed.kext (using OCAuxiliary tools)
disabled SecureBootModel in my config.plist using a text editor.
removed UTBDefault.kext from /EFI/OC/ACPI and the config.plist (using OCAuxiliary tools)
removed the Realtek Wifi kext from /EFI/OC/ACPI and the config.plist (using OCAuxiliary tools)
removed the UTBDefault.kext from /EFI/OC/ACPI and the config.plist (using OCAuxiliary tools)
removed igfxonln=1 igfxvesa from my config.plist using a text editor
Still can't make it to recovery menu.
Once I go "Install Sequoia.dmg", I get this scrolling text stopped right here(see picture attached).
But your support is unfathomable.
I'm also attaching updated EFI, in case it helps in some ways.
Thank you for reading this and special thanks for the aml files!
The verbose text is showing a number of ACPI errors. I will have a look at your new EFI folder to see which ACPI table(s) are causing these issues, when I am next at my desk.
