Ryzen 9000
Ejh4286
86
Ryzen5950
i would also enable this:
CaseySJ | IOPCIIsHotplugPort | Fix PCI bus enumeration on AM5 | 13.0+
and disable completely these two ones:
Visual | thread_quantum_expire, thread_unblock, thread_invoke | Remove non-monotonic time panic | 12.0+
@Shaneee why these two patchesa are enabled by default?
often for us they are problematic and noone explains an exact case where they are mandatory to boot or install
Have you followed latest BIOS thread for ASUS supporting new Incoming CPU?
It is weird if your 7950x boots with the newest BIOS of your motherboard because asus needs to patch some ACPI to boot in OSX with newer and older processors
He is using a DDST which could be the issue although that seems weird unless he updated the bios
it is not enabled i see (or i miss something)
The first DSDT entry in ACPI is enabled. Maybe he should disable it and see if these ACPI patches made for the Crossfire Hero X670E board will work.
Reactions: fabiosun
@Lorys89 x650e has only an ACPI patche done by CorpGhost so, maybe he needs one good for his motherboard
I see his hang and it doent seem realted if i am not wrong
Reactions: leesurone
This was unsuccessful.
also in 15,1 b4 patches work fine!
I tried putting the Ryzen 9700 in this machine, revised the core count in the efi on the usb and it booted just fine. I believe the problem is specific to the 9900x. I’m giving up for now.
@Ejh4286 have you a debug log of your failed boot with 9900 cpu?
just removed ryzen kext, stil agesa 1.201
Will test again with agesa 1.202 later
i can be pretty sure it's specific for 9900 CPUs(not my pc)
specs:
| [CPU][AMD Ryzen 9 9900X 4.4 GHz 12-Core Processor]
| [CPU Cooler][Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler]
| [Thermal Compound][ARCTIC MX-6 4 g Thermal Paste]
| [Motherboard][Asus TUF GAMING B650M-PLUS Micro ATX AM5 Motherboard]
| [Memory][Corsair Vengeance 128 GB (4 x 32 GB) DDR5-5600 CL40 Memory]
| [Storage][Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive](disabled with nvme=-1)
| [Video Card][XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card](disabled, owner said he doesn't need acceleration)
| [Case][NZXT H5 Flow (2022) ATX Mid Tower Case]
| [Power Supply][Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply]
| [Case Fan][ARCTIC P12 PWM PST 56.3 CFM 120 mm Fan x3]
@Shaneee could you check in some way this printed core counts for 9990 cpu?
it is weird :)
Well that's not right... Can I get a SysReport for this system please from a Debug OC.
