Ryzen 9000
Ejh4286
86
Ryzen5950
Sorry it took so much time to post it, here it is.
Unsure if it would affect the OC logs reporting 14 cores but your kernel patches were set to 1C (28). I've set it to 0C (12) please try again.
Hi @Shaneee they did many core counts try from 12,14 and so on
What do other systems report for the core count? Windows, Linux?
windows has a sort of activity windows where you can find all threads
also aida or CPUz give some informations
fabiosun told me to try and change them to 14 and then 28, they were 12 at first and it was still reporting the same issue, so i'm pretty sure that's not the issue
I assume Windows is reporting the correct core count? I'll revisit this later tonight and upload a new version to test. @fabiosun if you could also test just to be sure it still works on other chips too.
Reactions: fabiosun
Hi, for those who have managed to get macOS running on a Ryzen 9000, can you tell me if it's actually stable? for example : encoding a 4k stream with x265 (not VideoToolbox) with a veryslow preset. I can't last more than 45 minutes before my system restarts. I tried two motherboards (X670E CREATOR and B650E-E STRIX) with my 9950X and the result is the same. I have ran multiple tests and configurations under Sonoma and Sequoia. But can't find the problem...
Edit: added files
@Shaneee if others 9900x are reading without testing it is better they give an hand if they desire to have their hack working well
If this happen i will happy as usual to test in my yet working system
So 9900x users take time to give an hand to shaneee :)
Reactions: Shaneee
Any 9900X users tested this yet?
Reactions: fabiosun
Edit: added files
Give the command or something, and I'll test it
Sure, you can use Handbrake 1.8.2 with those settings on a 4K HDR/DoVI HEVC "BIG" file ;) :
  1. x265 10-bit encoder
  2. multi-pass with turbo first pass
  3. bitrate 30720 kbps
  4. Options:
    1. presets : veryslow
    2. profile : auto
    3. level : 5.1
    4. additional options : repeat-headers=1:hdr=1:hdr-opt=1:no-dhdr10-opt=1:aud=1:ref=4:gop-lookahead=0:rc-lookahead=60:lookahead-slices=1:rect=1:amp=1:tu-inter-depth=4:tu-intra-depth=4:limit-tu=4:psy-rd=2.00:psy-rdoq=1.00:rdoq-level=2:dynamic-rd=0.00:nr-intra=0:nr-inter=0:max-merge=5:limit-refs=2:no-limit-modes=1:me=3:subme=7:merange=57:weightp=1:weightb=1:deblock=-3,-3:rd=4:selective-sao=4:no-fast-intra=1:b-intra=1:aq-mode=4:scenecut-aware-qp=0:bframes=8:min-keyint=23:keyint=250:scenecut=40:hist-scenecut=1:early-skip=0:rskip=2:rskip-edge-threshold=5:vbv-maxrate=160000:vbv-bufsize=160000:vbv-init=0.9:min-vbv-fullness=50.0:max-vbv-fullness=80.0:aq-strength=0.80:limit-sao=1:high-tier=1
FYI, everything works perfectly well under Windows 11 and Ubuntu 24.10 daily
Likewise, these settings worked perfectly with my 7950X and my 5950X under Sonoma.
No problem running Cinebench 2024 (quite satisfied @145TDP (PBO 195/140/200), only 72°C):
But system goes into kernel panic after 30-45 minutes under heavy loads. (before someone ask, same results CPU stock (PBO disabled,...)).
New asus rog strix z670e hero 2403 bios
Installed and it works with the same acpi patches
Better memory performances in my system with 4 dimm installed
I don't understand. Three different caclulations and still the wrong core count. Can you test something for me @Alex4querty? I don't think it'll boot but try disable the ProvideCurrentCpuInfo quirk and send the log. I'm wondering if this is the cause.
Reactions: fabiosun
