The SSDT-USB-Reset.aml is failing to find the USB controllers. Probably needs a couple of APCI rename patches for your XHC1 and XH00 USB controllers. The first clashes with the Apple USB controller and the second is a duplicate controller. As your DSDT.aml has two controllers with the same/similar names.
Rename patches required for the two USB controllers, according to Corpnewt's SSDTTime script output.
The ACPI table has been removed from the EFI attached. See if that helps.
