tucano2000
168
134
43
Ryzen 1600X
*** First of all, don't make any changes to the vmware .vmx file. It is recommended that you create a new virtual machine from scratch so that it recreates this file by default and without any changes.
*** Use VMWare Workstation Pro version at the link provided in the tutorial. (If you install it, you will have to make a new Patch as described)
*** Enable AMD-V or INTEL VT (Virtualization Technology) in BIOS. (you should research how to do this on your machine)
1) First you need to download VMWare Workstation Pro:
- VM Workstation Pro 17.6.3: (NOW IS FREE FOR ALL USERS)
- Download Unlocker to patch VMWare:
- After installing VMWare close it.
Extract all the unlocker files into a folder, open the command prompt (terminal) in administrator mode and run "win-install.cmd".
This patch releases the Apple Mac OS X version configuration option in VMWare under Virtual Machine Settings, Options, Apple Mac OS X:
use "macOS 15" when configuring your virtual machine:
2) Also download an ISO of macOS:
Sonoma 14.7.6
Link1: https://mega.nz/file/tAkzQA5B#XJeNhYN4xKatkmObgRvbrZy0TD7vQi6-KJvKQ_SYOGk
Sequoia 15.2 ISO
Link1: https://data.pyenb.network/macOS/isos/torrents/macOS Sequoia 15.2_24C101.iso.torrent (Use Torrent app to download with this file)
macOS Sequoia 15.5 ISO (try a link that works better or you can download it)
Link1: https://hackintosh-images.ddns.net:10443/macos/Sequoia_15.5.torrent.zip (Unpack and use Torrent app to download with this file .torrent)
Link2: http://hackintosh-images.ddns.net:8090/macos/Sequoia_15.5.zip
Link3: https://mega.nz/file/pQ90jYqD#xauoqi4qGQTvRacRJ7i_xKXhnyR5WY6bvzC_byOcYTg
macOS Tahoe Beta
https://forum.amd-osx.com/threads/m...works-with-sequoia-sonoma-etc.4696/post-41807
Sequoia is working with Apple's login services (iServices). WMHide.kext and Lilu.kext 1.7.0 have been incorporated into the VMDK image Opencore updates.
Tahoe is working with Apple's login services (iServices) using iCloud Pacth. (AMD only for while)
3) Download a small VMWare disk image file:
INTEL PROCESSORS ONLY
This version only works with INTEL processors with any numbers of cores avaliable in your machine (test to better performance):
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4
https://mega.nz/file/YY9zSZ4C#PtilBDmBZV8DRhkGaA7xQBkjvllmGg8OyIp321MJ7Vk (FOR INTEL MACHINES)
This file contains Opencore 1.0.4 on an EFI partition and should be chosen as a disk image on the SATA 0:0 drive in the VMWare settings. It should always be used that way.
AMD PROCESSORS ONLY
This version only works with Ryzen processors with 4 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 4 cores
https://mega.nz/file/hQkUBKQY#2PeSE3cO4DFin5FLwcvEiEZqivyzALirTGUpR6lcNbU (FOR AMD MACHINES)
OR DOWNLOAD:
This version only works with Ryzen processors with 8 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 8 cores
https://mega.nz/file/AAsWGZqT#1o-0zbqc3imAQBv11C88pe-r3KuDRevEs_vZs06dyvo (FOR AMD MACHINES)
OR DOWNLOAD:
This version only works with Ryzen processors with 16 cores or more
Download New Version of VMWare disk image file Here: OPENCORE 1.0.4 - 16 cores
https://mega.nz/file/tVM03LQQ#uoG5oBeOhsTN8cyJwO7jR8g701ZIkzGbxuPA-LhpsMY (FOR AMD MACHINES)
OR DOWNLOAD
macOS Tahoe Beta:
VMWare settings FOR AMD/INTEL:
a) Memory:
8GB (recommended 50% of your host machine)
b) Processors:
Intel: Usually 50% of your machine's Intel processor cores.
AMD 4 cores (if you are using the VMWare disk image file with 4 cores)
AMD 8 cores (if you are using the VMWare disk image file with 8 cores)
AMD 16 cores (if you are using the VMWare disk image file with 16 cores)
c) Hard Disk (Sata):
macOS_Opencore_1.0.4_4_cores.vmdk or
macOS_Opencore_1.0.4_8_cores.vmdk or
macOS_Opencore_1.0.4_16_cores.vmdk or
macOS_Opencore_1.0.4_intel_.vmdk
in (SATA 0:0) Should always be the first boot drive.
In newer versions of WMWare choose "Keep existing format" if you are asked when adding the image of this drive.
4) Hard Disk 2 (Sata): This drive is where macOS will be installed. Any size you see fit.
5) CD/DVD (SATA): Use ISO image file (Ex. Sonoma.iso, Sequoia.iso, etc.)
6) USB Controller 3.1.
7) Network Adapter: Bridged Automatic.
Note:
- After installing macOS, if the internet doesn't work, check that the configuration file that was created in your virtual machine folder (.vmx file) contains the line:
ethernet0.virtualDev = "vmxnet3"
- After installing yet, change the Automatic Brigade mode to choose your computer's network adapter as explained in this post:
Click Here
Installing macOS
It is recommended that you read and make the changes mentioned in Item 8 of this tutorial before starting the installation.
When you start the virtual machine to install macOS, choose the CD/DVD drive that was attached by the ISO file in the VMWare settings labeled "Install macOS Sequoia" or "Install macOS Sonoma".
After, during installation, only erase or format the macOS installation drive you created using Disk Utility. Never do this on the OPENCORE drive (it must remain untouched):
ATTENTION !!!!!!!
8) (IT GREATLY IMPROVES PERFORMANCE AND CORRECTS ERRORS :)
Before Installation:
In order to correct the “errors” during start-up, which in spite of everything works.... and also to correct the performance and reduce the “slowness” of the virtual machine, you should turn off the windows hypervisor. To do this, use the tip below:
- In Windows, click on Start and search for Command Prompt.
Right-click Command Prompt and then click Run as administrator.
If the User Account Control dialog box appears, confirm that the action shown is the one you want and click Continue.
Then type:
bcdedit /set hypervisorlaunchtype off
(and Hit enter)
Then type:
reg add "HKLM\SYSTEM\CurrentControlSet\Control\DeviceGuard\Scenarios\HypervisorEnforcedCodeIntegrity” /v “Enabled” /t REG_DWORD /d 0 /f
Press enter again.
Restart the computer.
- It is also recommended to disable the "Memory Integrity Checks" in Windows to improve performance.
After Installation:
- Install VMWare Tools to change the resolution. It comes with VMWare Workstation, I don't remember if VMWare Play has VMWare Tools.
- You can only change the resolution within MacOS. Ex: 1600x1100. To do this, type in the terminal :
sudo /Library/Application\ Support/VMware\ Tools/vmware-resolutionSet 1600 1100
Note: In VMWare's Display settings you need to set the resolutions higher than or equal to the ones you'll be using in macOS.
Issues:
Crash, Stopped during installation or Repetitive errors when loading the system
It was probably discovered that windows hypervisor hinders the normal functioning of VMware. You should turn it off. It can be done at the end of everything even after macOS is fully installed. See item 8.
White background (wallpaper)
***** When I first got macOS, I had this problem with a white background (wallpaper) in the system background. But you have to go into the macOS settings and click on Wallpaper and then deactivate the Show as screen saver option. Then choose a wallpaper you like.
SLOW UPLOAD SPEED
A problem with file upload over the network has been reported in some specific access cases that makes the network very slow when sending a file.
This happens due to a problem with the vmware vmxnet3 network driver.
I tested this solution and managed to solve this problem.
Open the Mac terminal and type the commands below in sequence:
sudo sysctl -a | grep net.inet.tcp.tso
sudo sysctl -w net.inet.tcp.tso=0
sudo nano /etc/sysctl.conf
Add the below entry in the sysctl.conf file
net.inet.tcp.tso=0
Press Control + O to save and then Enter to save. Control + X to exit.
Restart macOS.
WOW!!! :love:
Your setup has passed the reboot shutdown!!! (y):love:
Dear Friend,
I could get the first GUI with a large OpenCore Disk. After I had clicked on it, a dark screen stayed there forever.
Do you know the reason? :unsure:
Hi HKPhysicist.
in vmware I have set this default video configuration:
Never choose OPENCORE. It's only for automatic booting when you start the machine.
If you're installing for the first time, quickly tap the screen as soon as the icons appear and choose Install macOS Sonoma if you've added the ISO file to the CD/DVD drive. Never tap or choose OPENCORE because it will give you a black screen.
On subsequent reboots, another icon will appear with the name of the drive you created during the installation, but it will automatically be selected.
WOW!
Your OpenCore bootloader was able to boot up and passed the first installation reboot! The hard disk stage installation is in progress. Let me see where its destination is. :love:
Another secret is - the VMWare unlocker only works for VMWare Player v17.0.1 or older. Otherwise, macOS will complain that my VM is not eligible for the present installation macOS 14!
I recall that my failed setup received this alert logo when I ran my macOS 14 installation on a patched VMWare Player 17.0.2!
It implies that macOS 14 installation is able to recognise a wrongly patched VMWare Player 17.0.2 as a fake macOS VM! :LOL:
Hello Friend,
You also have to install VMWare Tools from within macOS. It will turn your mac display to wide screen!
Hello Friend,
With the help of your customised OpenCore, my Windosh VMWare VM installation is a complete success! I am installing XCode from within macOS 14 VM. :love:
Another question is -
Do you also use GenSMBIOS tool and OpenCore plist to configure your virtual iMac specification?
Reactions: tucano2000
Hello Friend,
Excellent News !!!
I use OC Auxiliary Tools to edit and configure the opencore config.plist file.
You can use this tool to edit this file and configure new SIM Bios and use another one for your virtual machine:
Editing SMBIOS:
Before you can edit it, you need to mount the OPENCORE partition. This partition contains the EFI directory and, inside it, the OC directory, where the config.plist file is located, which must be opened with OC Auxiliary Tools:
Use ESP MOUNTER PRO or another application to mount the OPENCORE partition:
When opening and editing the config.plist file, be careful because an error can make the machine unbootable.
I create 2 virtual machines here and open the opencore vmdk file from another machine as a secondary drive to correct errors in config.plist in case it is no longer bootable:
You can edit OPENCORE from the virtual machine itself without having to use 2 machines. But you must make sure you know what you're doing. Editing SMBIOS, for example, and choosing a Mac that is not supported by macOS Sonoma can cause the system to stop booting.
As far as I know, Macs manufactured after 2019 support macOS Sonoma.
WOW! A full suite to build Ryzentosh PC and Windosh VM! (y):love:
TYSM, a huge time saver.
Note: Use a solid background as a wallpaper to increase responsiveness.
Many Thanks! You have done a excellent job!
I edit setting to 8 core 64GB RAM work perfect.
Hello Friend,
No need for a custom SMBIOS, it uses VMware1,1 (or something like that) by default. Just set SpoofVendor to true.
False***, Damn the shadow ban about no message edits.
Yes.
Yes. You can edit the OPENCORE volume as I showed you how to do earlier and open the OC Auxiliary Tools, accessing Kernel, then the Patch tab, under Replace, there are those first 4 lines in hexa B9 XX ... and BA XX ... where XX is the number of cores you're going to use in VMWare.
Today, I made a new macOS Sonoma 14.1 VM with this recipe! It is a complete and smooth success! (y):love:
Following the information in this post, I put the iMacPro1.1 in SMBIOS and both Sonoma and the XCode Simulator seemed to run and load a little faster. Confirm if the same happens.
