@thecastic,
Had a quick look at your EFI. Looks like you may be missing a SSDT-CPUR.aml for the CPU & SSDT-HPET. You also don't have any Tools added into your OC/Tools folder. At the least you need ResetSystem.efi. Also you are using the wrong SSDT-EC-USBX for the embedded controller - you are using the Desktop version not Laptop which is the one you need and also no custom USB map nor USBInjectAll. So I have added these in for you and disabled kexts and SSDTs I don't think are needed for the initial setup such as AMDTscSync and a few others. Your SSDT-SMBUS & SSDT-MCHC is more than what I expected so I have simplified it to SSDT-SBUS-MCHC. Also removed the Max version setting from the NVMEFix.kext because it interferes with your Ventura setup.
As for everything else they largely look correct, especially use of NootedRed for the AMD IGPU. I also arranged the loading order of the kexts. Give it a try.
