Ryzen 7 4700G — Ventura 13.5 & Sonoma Public Beta — Radeon Graphics 16 GB [Renoir] — NRed
Hi Steve,
So I've had a quick look at your EFI. As I also have an AMD Ryzen APU setup, I do think I know what the problem is (as to why it's not booting up properly).
In your ACPI I see you only have SSDT-EC-USBX & SSDT-CPUR enabled. However I noticed some systems like mine (VCS) also need the following before they can boot:
SSDT-HPET.aml
SSDT-PMC.aml
SSDT-SBUS-MCHC.aml
Extra patches under ACPI > Patch from OC
Settings disabled in BIOS: (From Steve: All Done)
SVM
TPM Trusted Platform Module / SecureBoot
boot-args
npci=0x3000 (My BIOS support forced 4G memory for IGUP and opened already)
So what you need to do is run SSDTTime from Windows, extract your DSDT (for the SSDT creation process) and add the SSDTs it recommends (which includes the above)
as well as the mentioned settings. (WIll try later and much appreciate for your input !!!)
Hi Middleman, Pls kindly find my comments above in yellow.
Thank you.
Good day !
Reactions: Middleman
@Steve901 good job, what did you do to get it to boot?. Interesting that in Big Sur System Information, Graphics and Displays says your 4600G is Cezanne.
Hi Craig, I mapped USB which I planed previouly after system installation, add more drivers :
USBToolBox.kext
UTBMap.kext
Innie.kext
NVMeFix.kext
However, the good pictures I took just is the screenshot.
What I see from my eyes now like this:
img_2562-jpeg.11498
  • Love
yeah not very useful despite being pretty. How much RAM do you have installed on your system?. In BIOS what other VRAM settings are available ?.
  • Haha
Aha, Thank you ExtremeXT, then I will try to update the system based on this version, if it's works then I will try a clean installation with Ventra again.
Super !
Hi @ExtremeXT, I wondered if you would take a peak at my bad EFI for a Gigabyte B450M DS3H WIFI paired with a Ryzen 7 4700G. I haven't tried the AmdTscSync.kext before, but I'm sure that's not the reason for black screen after verbose. I created that random pile of SSDTs in SSDTTime on Windows 11 pro and threw them in there hoping for the best. Attached below, SMBIOS removed.
Fixed it. Yeah No Man's Sky looks good, I will have to post a video with this setup. Haven't fixed internet will work on that later.
You have duplicate SSDTs lol. SSDT-EC and SSDT-USBX make up SSDT-EC-USBX-DESKTOP. You're supposed to use SSDTs from SSDTTime: HPET, EC, USBX, PLUG + ACPI patches and nothing else. AMDTSCSync is for laptops only, and even there, only problematic ones with an unsynchronized TSC.
Reactions: craighazan
I got it booting with this.View attachment 11512
I Craig, I successfully installed Monetary, with this EFI and updated to Ventura.
Only need to be patient during installation, I was about to give up, and thought it would not make it. but at the end it went through !
But I could not manage to get VDA working. Any thought about this ?
I you have problem with you B450M, maybe try my EFI. remember mapping the USB port for your own.
Known issue on macOS Big Sur with NRed, update to Monterey or later and it should be fixed.
Really appreciate for your information, otherwise I am still finding and trying the solution to the wrong display !!!
View attachment 11516View attachment 11517View attachment 11518
VCN support in NRed is experimental, no support if you encounter issues with it, -nredvcn.
The solution is... to upgrade macOS lol.
@Steve901 Could you attach your EFI for me to look at?. Ill attach mine when I get home from work later.
I thought I had attached in my previous message. maybe the connection issue, the attachment was missing.
Anyhow, pls find it here.
  • Love
Yes, I manage it by -nredvcn, seems not stable.
Thank you !
You're the best!, I've attached mine too for the Gigabyte B450M DS3H WIFI. Steve keep us up to date with your build please, your HDMI audio knowledge will be really appreciated.
anyone, please help me...Sir, I have Desktop Ryzen 7 5700G and Asus b450 motherboard...Kindly please help me to install macOS with this APU..I don't have a budget for the new MACbok..please anyone help me to create EFI..I am ready to pay little amount
Here is my configuration...Screenshot 2023-08-01 190256.pngScreenshot 2023-08-01 190315.pngScreenshot 2023-08-01 190343.png
I read all msg in Thread..I think your more experience and intelligent person. Great work bro...Kindly Please help me...I can pay you a little...Please
