Ryzen 7 4700G — Ventura 13.5 & Sonoma Public Beta — Radeon Graphics 16 GB [Renoir] — NRed
Ok..a
4g encoding and resizebar should be disabled for my Asus b450 motherboard right?
That is correct. Then add the boot argument ‘npci=0x0300’ to your EFI.
Right now..I have windows system how can i add this in via windows system
I am sorry..I am Bothering you guys.Thanks for your help
Done it for you, just replace the config.plist in your EFI folder with the one attached here. I will be going to bed soon, just to let you know.
Thank you so much sir..Please msg me if you want any help in App and website development..I want to help you too
Not showing
Macos installer..Just showing windows boot
hello, guys, I had setup all things all goes well but after being verbose and just before the language picker I got black screen, Here I smy configuration Amd Ryzen 7 5700g, Asus B450 motherboard, No Graphics card,32 GB RAM and Wd green data SSD...I am also attaching My Efi kindly please check
Sir kindly Please check my above efi file #88
Reactions: craighazan
Try booting with this EFI-V1 attached. See if this helps.
Sir kindly Please check my above efi file #88 ..I got black screen just before Language pick option
@digu3120 It must be a BIOS setting that's wrong. I'm going to reboot into BIOS, reset to defaults and post my changes.
ok sir..Please guide me
So I reset my BIOS and made the following changes and booted back to Sonoma. Also check that CSM, Above 4G Decoding and SR-IOV are disabled.
Sir i did same bios setting as per your guide but still same issue..please look my efi again #88
. Here you can see what is exact issue...I already did previous steps like download recovery image and install..this is last step for select language but before that i got black screen..please help me sir
Try this one. You should also generate your own SSDTs for your EFI, it mentions this on NootedRed.inc, better done in Windows.
I upgraded my motherboard again to a ASUS Prime B550M-A AC, paired with the 4700G that's a pretty good budget gaming build contender right there. Not the boost the 450 saw over the 320, but definitely, visually at least, much better to look at and watch. I feel Hack Desk episode 1.0.9.3 in the making.
Reactions: Middleman
Thanks for your efforts bro...But problem still exist..Same blak screen but i really appreciate your help..
Thanks guys..Problem solved after adding smclight sensor.kext..thanks you all off you...thanka from my bottom of the heart
  • Love
Xcode simulator Not working..Showing black screen.please guide me
