Gigabyte B650M Aorus PRO AX (rev. 1.0) EFI - Adaptable to Gigabyte B650 boards
jubarim
67
28
18
Campinas, Brazil
Ryzen 9 7900X
** This is just a preliminary version for this Gigabyte AM5 motherboard that could be adapted to other boards
Parts used in my build:
  • Gigabyte B650M Aorus PRO AX (rev. 1.0) - bios F4b (F4 was released, I need to update)
  • AMD Ryzen 9 7900X 12-core 24-thread processor
  • TBD Radeon RX 6xxx GPU ( I had to return the 6800XT because it was crashing in games and rebooting in 3dmark spy test)
  • 32GB Kingston 5600MHz CL40 DDR5 with AMD EXPO support and RGB that NEVER EVER turns off in sleep, this is killing me) (2 x 16GB modules)
  • Corsair CX750M PSU
  • Asus TUF 120mm Liquid AIO
26 March 2023:
Added first version of OpenCore 0.9.0 EFI Folder - there is still a lot to do: no USB patches, nothing done yet.
## Credits
  • Special thanks to @CaseySJ, @Lorys89 and @Cheesetoast , without their help this would be very hard.
  • Dortania for their awesome guides.
  • @CorpNewt for Gygabyte patch
  • And anyone else that helped to develop and improve hackintoshing.
## References
Releases:
  1. OpenCore 0.9.0 - Ventura - with usb port mapped.
  2. 02_oc090_Ventura_13.2.zip: Ventura 13.2, OC 0.9.0, Motherboard updated to BIOS F4. This version is much more stable and based on @Kubokun EFI here.
  3. EFI3_oc092_Ventura_13.3.1a.zip - OpenCore 0.9.2 - Tested with Ventura 13.3.1a.
  4. EFI4_oc094_Ventura_13.5.zip - OpenCore 0.9.4 - Tested with Ventura 13.5.
Note: remember to add your own serial / model etc before using the EFI.
  • Love
Reactions: Kubokun and svan71
Updates:
22 March 2024
OS: Ventura 13.6.5
Opencore: 0.9.7
My build is not stable in sleep mode. Sometimes it just powers off and this week it's rebooting. Not sure what happened, maybe it's the latest Ventura 13.6.5 I updated to.
I just updated my BIOS to F22b, not sure if it will help, probably not, I will let you know.
Any hope for an update with 0.9.2 ?
Reactions: jubarim
Sure, I will post it now, please check the second message update.
Thanks bud, my board is arriving tomorrow hope to be up and running by tomorrow night this should really help allot.
I had no sound but I was able to fix, enabled patch 17 "CaseySJ - Fix PCI bus enumeration on AM5 - 13.0" and switched to SSDT-EC-USBX-DESKTOP.aml and removed SSDT-EC-AMD.aml as per Shaneee suggestion. So far everything is working well including sleep no LAN though that's the only problem. This was patched for 7700x as well the rest of my info is in my sig.
Reactions: Shaneee
inject this kext to config.plist for LAN
@jubarim Gigabyte recently release f5d bios and it fixed the onboard audio , a little cpu vcore offset , worked perfectly for mine
  • Love
Reactions: jubarim and svan71
Thanks alcid 11 worked for me then I did it the more permanent way.
LAN working :) thank you Kubokun.
Reactions: jubarim
Bios F6a OpenCore 0.9.2 all Kexts and drivers up to date. Audio, LAN, Sleep all working perfectly. Patched for 7700x. Thanks jubarim for starting me in the right direction and Shaneee who is always there to help.
  • Wow
Reactions: jubarim
Hi! Sorry for taking too long to enter here.
I'm glad it helped. This is the work of everyone here.
By the way, I still have to update my bios to the latest one, there are releasing lots of bios these last weeks. The last one is F7a...
Reactions: svan71
Bios F6 OpenCore 0.9.3 all Kexts and drivers up to date. Patched for 7700X. I have learned personally to avoid the BIOS a,b,c versions unless I have a specific issue they address. I'm sticking with 6 now until 7 is final.
hi, my motherboard is b650m aorus elite ax and I try to adapt your efi for my 7950x. when I install macos into my nvme it reboot over and over again even it cannot show opencore menu. what should I do
You have different CPU Core Counts, 16 vs 12 for the 7900X, so you need to adjust those in the kernel patches in your config.plist. See here for more information
Reactions: jubarim
thx for reply,but I still have problem. adjust the value to hex 10 with 16 cores and process type to 3841. but same as before
Please upload you zipped EFI folder after removing serial numbers etc so someone can help you further. Also please double check your bios settings.
BIOS Settings
  • Boot -> Secure boot -> Key Management -> Clear Secure Boot Keys
Reactions: jubarim
